Well I pulled the Eaton off this morning to make room for the new Whipple. It was very straight forward. Here's how it went.
First I pulled the belt off.
Then I unhooked the battery and just pulled it out.
Next I unhooked the Mass Air and tube from the Throttle Body and JLT CAI.
Then I jacked the car up and drained the IC fluid then hooked the HE hose back up.
Back up top I pulled off the IAC and throttle cable.
Then on to the other side to unhook the plugs and vacuum lines.
Then I pulled off the Fuel Rail.
Next was the Elbow and some more vacuum lines.
Then I unbolted the intake and blower and IC manifold and pulled it off. I also put towels down each port to keep stuff out.
Here it is along with the intake. You can see it needs to be cleaned up.
I also marked everything and put them into Ziplock bags.
Oh and one of the garage and car.
Now its off to pick up some supplies and get something to eat.
