Just installed c4 trans in the 89 musatng trans is bolted up and torque converter is bolted up. The question or problem I have is the engine is very hard to turn with a breaker bar on the crank. Has anyone every ran into this before? As far as i know the converter is seated properly in the pump. Should I pull in back out and double check the converter? thanks Jason
