cam sensor
Discussion in '94-04 V6 Mustang' started by jozan, Dec 16, 2007.
  1. jozan New Member
    Aug 27, 2005
    Message Count:
    61
    has anyone had this thing start squeaking almost like a belt or bearing going out
    i replace the alt the idler and tensiner pulleys and the water pump has maybey 5000
    miles onit this noise could be the rear bearing on the pump but it was a new pump from oreillys but that is the area of the squeak its a 96 3.8 automatic with 124,000
    thanks for any help
  2. Firefighter_emt New Member
    Sep 17, 2006
    Message Count:
    Thomasville, GA
    I had this problem but my car also was skipping something fierce. I replaced the entire camshaft angle sensor and it fixed everything. The terrible screeching sound is he bearing in the actual sensor itself. Pull it out making sure that you mark the position of the sensor. If there is any play in the shaft the bearing is bad.
  3. jozan New Member
    Aug 27, 2005
    Message Count:
    61
    ok thanks alot it seems to have stopped for now but i will pull it out and check it how much are those thiangs and can you get them from parts store
  4. Firefighter_emt New Member
    Sep 17, 2006
    Message Count:
    Thomasville, GA
    I got mine from Napa and it was around $100 with the sensor included. My noise would come and go also. Sometimes it would skip and screech and others it would do nothing other than a high RPM skip
Share This Page
