Can someone take a pic of their factory radio power connector for me?
Discussion in 'V6 Talk' started by Jamez, Feb 26, 2004.
  1. Jamez Founding Member
    Mar 2, 2000
    Message Count:
    2,610
    I think I've got something in the wrong spot as I get a pop after turning the car off from the speakers after reinstalling my factory radio. I assume '94-8 non-mach radio connectors would be the same as far as the wire colors and such. The connector I'm talking about is the one on the back of the am/fm radio that has the power cables, not the smaller square one for the speakers. Thanks
  2. SonicBlue02-3.8 New Member
    Jun 28, 2003
    Message Count:
    112
    i believe if i recall correctly that the popping is due to a grounding problem. I wonder if your factory ground connection is loose or something. Also, it could very well be the headunit is going bad.
  3. Jamez Founding Member
    Mar 2, 2000
    Message Count:
    2,610
    That could be it, but I haven't used it in so long cause I've had a cd player that I don't remember if I put all the wires back where they were after taking the connector itself apart.
  4. jrc_03_gt New Member
    Jan 1, 2004
    Message Count:
    789
  5. 75player New Member
    Dec 22, 2003
    Message Count:
    58
    Dumb question here, but why did you take apart the connector? Do you mean you took the wires out the connector shell?
    I'm in the process of chasing down an engine noise problem so I should be able to take a couple of pics for you this weekend.... Just let me know if you want me to post them here or just e-mail them to you.
    George
  6. Jamez Founding Member
    Mar 2, 2000
    Message Count:
    2,610
    That'd be awesome. Actually I had planned (don't laugh) on taking the connectors off and straight soldering them to my cd player harness. I was 16 and knew nothing of stereo systems although I could solder very well so I attempted to put them together. Luckily I had trouble finding out which wire did what and went to Circuit City where they told me what was up. The factory radio doesn't dim now either so I know I've got at least one in the wrong spot.
  7. Jamez Founding Member
    Mar 2, 2000
    Message Count:
    2,610
Share This Page
