Car Diesels
Discussion in 'Fox 5.0 Mustang Tech' started by TK_05, Jan 25, 2004.
  1. TK_05 Member
    Feb 12, 2003
    Message Count:
    286
    Las Vegas
    my car diesels (continues to run even after key is removed)...
    im thinking my fuel pressure is messed up but i just want to be sure.. what are some other causes for this? thx
  2. bmorrisj New Member
    Sep 26, 2003
    Message Count:
    449
    Buena Park, CA
    sounds like fuel is somehow getting into the cylinders and detonating, you might want to check compression ratio on the heads ... what gas are you using?
    Sponsored Ad
  3. thegabrielles New Member
    Feb 26, 2003
    Message Count:
    516
    Atlanta Georgia
    Bad gas, timing to far advanced/retarded, since you have a fuel injected car I would not think it can be to much fuel.
    Has it been doing it long? Or did it just start? Hopefully you just got some bad gas.
  4. TK_05 Member
    Feb 12, 2003
    Message Count:
    286
    Las Vegas
    its been doing it for a while... i just reset the timing... think i set it to 12* or 14* cant remember... i use 91 octane... car idles a little under 1K... any opinions?
  5. IndyBlk5.0 New Member
    Nov 25, 2003
    Message Count:
    1,136
    New Whiteland, IN
    do you have an electric fan? bad wiring could be the problem if so.. sounds like an ignition problem. correct me if im wrong, but what should happen when you turn off your key, it kills the injectors and coil... therefore you would get no spark, and no fuel. only way i can think of it running after key off is an ignition problem
  6. TK_05 Member
    Feb 12, 2003
    Message Count:
    286
    Las Vegas
    yea i got an electric fan and the ****tard who owned this car before me cant wire for **** so bad wiring is ALWAYS a possibility... i dont even know what to check for wiring wise..
  7. makarov New Member
    Jul 10, 2003
    Message Count:
    181
    Forestville, CA
    What's the heat range on your spark plugs? Stock or hotter have a longer insulator and dissipate more slowly than a colder plug and shorter insulator. The hot plugs can stay hot enough to burn anything within reach in the combustion chamber, carbon, unburned fuel, etc. after the engine is shut off. The trick is to get the coldest plug you can without fouling. Most engine guys recommend a colder heat range for every step up in timing or boost. You don't mention an aftermarket ignition in your sig, but with an msd, crane, etc., you can run a colder plug because of the spark energy produced by the aftermarket boxes keeps the colder plug from fouling. Hope that helps, good luck.
  8. TK_05 Member
    Feb 12, 2003
    Message Count:
    286
    Las Vegas
    i run some copper autolite plugs same heat range as stock... i dont see how that could cause it to diesel tho? the ignition is stock.. i got 24# injectors and converted to MAF...
    sometimes ill turn it off and the car will shut off then spike back up then off again... i can even turn the key off then back to the on position and keep it running... i hate this car... :notnice:
  9. IndyBlk5.0 New Member
    Nov 25, 2003
    Message Count:
    1,136
    New Whiteland, IN
    where is your fan pulling its juice from? if its tied to your coil any way at all it will keep the car running for a while by the fan turning and creating energy like an altenator, my car did this...
  10. makarov New Member
    Jul 10, 2003
    Message Count:
    181
    Forestville, CA
    TK, you almost answered your own question. Stock ignition and stock plugs and running 12 to 14* of timing on a pretty well modded motor. Stick with the autolites, but go one range colder than stock as a start. If that doesn't work, try two ranges colder. It's a cheap fix, and I can just about guarantee that's your problem. And with your mod's, invest in an aftermarket ignition, if possible, and a fuel pressure gauge.
    You might start by pulling some plugs. Look for damage on the ground strap and specks on the insulator (aluminum balls from the pistons), and if it's bright white, it's lean and hot. If you don't have one already, invest in a fuel pressure gauge, and adjust accordingly to get rid of the problem. I'd start with the plugs and then go to fuel pressure. You have to remember that you've done alot of performance mod's to the motor, so try to think beyond the stock plugs, fuel pressure and ignition. These are important upgrade items also. By the way, I'm not trying to rag on you, I'm just speaking from experience over the years.
  11. TK_05 Member
    Feb 12, 2003
    Message Count:
    286
    Las Vegas
    ok ill try that.. plugs are cheap... what should i set my fuel pressure at? i used to have a guage but i gave it away.. guess ill have to invest in a new one... the ignition will have to stay stock because im close to selling the car and dont want to put any big money parts into it... hope it something cheap thx for the info :nice:
  12. IndyBlk5.0 New Member
    Nov 25, 2003
    Message Count:
    1,136
    New Whiteland, IN
    where are you pulling your juice for your fan?
  13. TK_05 Member
    Feb 12, 2003
    Message Count:
    286
    Las Vegas
    im pretty sure its tapped into the fuse box... if i had a decent camera i would take a pic... :shrug:
  14. jrichker StangNet's favorite TOOL
    Mar 10, 2000
    Message Count:
    18,886
    31
    98
    Dublin GA
    If it diesels after you turn off the ignition switch, it is still getting fuel.
    The computer shuts off the injectors, so one way for it to continue to get gas is if an injector is leaking.
    The other path for fuel to get back into the intake is a leaking fuel pressure regulator. If the diaphram leaks, it will vent fuel back into the intake by the vacuum line
  15. TK_05 Member
    Feb 12, 2003
    Message Count:
    286
    Las Vegas
    how do i go about checking for these?
  16. jrichker StangNet's favorite TOOL
    Mar 10, 2000
    Message Count:
    18,886
    31
    98
    Dublin GA
    The fuel pressure regulator is easy - remove the vacuum hose from the regulator prior to shutting off the engine. If it is leaking past the diaphram, fuel will come out the vacuum port where you removed the line.
    The injectors are harder, pull all the spark plugs and look for a plug that shows evidence of carbon fouling. The bad injector will usually make the spark plug insulator much darker than the other spark plugs. Replacing the defective injector with one from the junkyard is the fix. Cost is about $10 per injector where I live.
  17. TK_05 Member
    Feb 12, 2003
    Message Count:
    286
    Las Vegas
    i heard this for the injectors.. drive the car fairly hard... rev it up a little bit then shut it off before ruturning to idle... coast to a stop and check the plugs.. if any if them are wet then thats your problem.. could that work?
  18. Icepick Founding Member
    Jul 30, 2002
    Message Count:
    380
    Ft Lauderdale
    as per Haynes, take it for what it's worth.
    1. Idle speed to high
    2. Electrical solenoid at side of carb (if equipped) not working properly
    3. Ignition timing incorrectly adjusted
    4. Thermo controlled air cleaner heat valve not operating properly
    5. Excessive engine operating temperature. Probably causes of this are malfunctioning thermostat, clogged radiator, faulter water pump.
  19. TK_05 Member
    Feb 12, 2003
    Message Count:
    286
    Las Vegas
    yea im going to double check all of these... anyone have a suggestion on the injector thing? how do i go about checking them?
Share This Page
