Car won't Idle
Discussion in '2.3L (N/A & Turbo)' started by t3-svo, Apr 25, 2005.
  1. t3-svo New Member
    Apr 19, 2005
    Message Count:
    76
    Mooresville NC
    I have an 86 Svo that won't idle. I have had it checked out and the guy thought that it was the vane air flow meter. I replaced it, it did not help. i have replaced:
    Vane air flow meter
    Fuel filter
    Throttle position sensor
    Idle air control valve
    New filters
    I know that my car is running rich because i can smell it in the exhaust. Could this be part of the problem?
    Plus I just got a code scanner but have not had a chance to use it.
    Any ideas?
  2. Keasbey New Member
    Jun 12, 2003
    Message Count:
    928
    Montreal
    is there any vacuum leaks? when you say won't idle, you means it would start and die if you don't press on the gas pedal? if it's that, I've got the same problem few weeks ago, and I changed the Fuel pressure regulator, and all the gasket of the intake (except the one between the block and the lower intake..) and now it's ok..
  3. TurboCoupeWHITT New Member
    Aug 16, 2004
    Message Count:
    46
    Ashland,Ky
    yes i agree check all the vacum lines ... and everything thats hold boost ... mine dont the samething and one of my vacum lines was unpluged..
Share This Page
