Check Engine Light
Discussion in '94-04 V6 Mustang' started by ZincPony, Jun 19, 2005.
  1. ZincPony New Member
    Jun 15, 2005
    Message Count:
    84
    this might be a stupid question and have and obvious answer but im just very paranoid.
    i was driving yesterday and the check engine light came on.
    i dont know whats wrong with it. my car has around 59k miles on it.
    The oil was just changed 500 Miles ago. i checked the oil it was golden and at the max. Radiator is full, according to the gauge the engine temp is right were it should be. washer fluid is full. everything is full and i havent noticed anything stand out. Im takin it to get it scanned and checked out.
    Should i be worried about this?
  2. east_sidaz40 New Member
    May 14, 2005
    Message Count:
    190
    do you have an aftermarket o/r H or X pipe on the car?
  3. ZincPony New Member
    Jun 15, 2005
    Message Count:
    84
    NO as of right now the car is fully stock. I havent dont anything to it yet.
  4. zincyellow03 New Member
    Jul 6, 2004
    Message Count:
    888
    Hmmm...zincpony...this board isn't big enough for TWO zinc cars!
  5. MNstang2002 New Member
    Jun 19, 2005
    Message Count:
    Similar Problem
    I have a 2002 with 63,000 miles on it. The Check Engine light just came on and I brought it to autozone and the code was P1285 (Fuel Air Meter Control). What does this mean and what is involved in fixing it? and cost?
    I checked other sources about the code and it said that P1285 means Cyclinder Head Over Temperature. Any idea on which is correct?
    The car seems to run OK in general, but the gas mileage has been down slightly on the past two tanks.
    Any advice/inisght is great appreciated.
  6. bdcardinal tree hugger
    Jun 10, 2003
    Message Count:
    3,670
    56
    go to autozone and get the code pulled for free. if you look on the 4.6 tech section, there is a list of the most common codes.
  7. ChingonStang New Member
    Sep 19, 2004
    Message Count:
    865
    Check Engine Light will always deal with your fuel emissions systems.
  8. bdcardinal tree hugger
    Jun 10, 2003
    Message Count:
    3,670
    56
    negative. there are about 10,000 different reasons why the CEL will come on.
  9. ZincPony New Member
    Jun 15, 2005
    Message Count:
    84
    wait so like Autozone can get a code on what the computer things its wrong with the car.
  10. AndyG47 New Member
    Aug 21, 2004
    Message Count:
    124
    Yes they will tell you the code for free.
    Side note I know that a "P1408 EGR Flow rate out of range, insufficent flow." = DPFE Sensor is shot.
  11. ChingonStang New Member
    Sep 19, 2004
    Message Count:
    865
    Oh yeah? Name some of them please that don't deal with the emmissions systems. I am curious.
  12. stargate160 New Member
    Apr 15, 2005
    Message Count:
    40
    I had a CEI after I installed I had a K&N Cold Air Intake professionally installed. It said the MAF sensor reported low reading and the temp. sensor reported too high readings. This is weird cause the CAI should increase the amount of COLD air. Anyway, never got the problem fixed. Got rid of the K&N and put the stock back.
    Pep Boys charges $20 to have the code checked.
    Autozone is free. Go there. They can scan it, pull up on the computer what the problem is, and print it out for you.
  13. bdcardinal tree hugger
    Jun 10, 2003
    Message Count:
    3,670
    56
    there are codes for the chassis electrical systems, ive pulled codes for taillights being out, there are codes for wiring harness and network problems. then there are ABS codes.
  14. ZincPony New Member
    Jun 15, 2005
    Message Count:
    84
    when the gas is pressed theres this noise coming form the engine when accelerating either slow or fast.
    im a try to go AutoZone tomorrow and see what the code i get is.
  15. bdcardinal tree hugger
    Jun 10, 2003
    Message Count:
    3,670
    56
    what kind of noise?
  16. tack New Member
    Mar 31, 2005
    Message Count:
    55
    Cold Air Intakes don't really lower the temp of the air going into the car. It just pulls in the air, most often times, from the fenderwell which is farther from the engine. The air is not in the intake system for anytime at all, let alone enough time to cool off. Pretty much what the intake system does is just give the air a nice smooth surface to travel against, resulting in a bit of a faster travel time, meaning more air can be sucked through. The name is kind of misleading.
    You could buy a cryo system for your intake then it would cool the air going through there but it's pretty much a waste of money.
  17. OxMox turkeysammichesonhisface
    Mar 31, 2005
    Message Count:
    611
    :chair: ...This could get nasty. Lol
  18. ZincPony New Member
    Jun 15, 2005
    Message Count:
    84
    oh very nasty haha. me and him have to go head to head in fight or race to death or join forces and take over THE WORLD MUAAHAAHAHAHAHA *EVIL LAUGH
    anyways i went to the AUTO ZONE the code they gave me was
    P0401 Insufficient EGR Flow.
    can those little fuel system cleaners take care of this or do i have to get the Ford Engine Carbon-Build-up clean-service or what ever the dude on the phone said. Truthfully i dont even know what the problem really is. I have no a clue what EGR is.
  19. zincyellow03 New Member
    Jul 6, 2004
    Message Count:
    888
    No you didn't! :D I gotta sign your gb on your cardomain site soon, lol.
  20. ZincPony New Member
    Jun 15, 2005
    Message Count:
    84
    alright well i got the little fuel injector cleaner thingy injected in my fuel. I need to see if that will do the trick but i am seriously doughting it. Just being hopefull. but man i dont wnana have to pay 54.99 for part then then labor to replace the EGR Valve
    zincyellow so i guess the ants are going to be bowing down to us soon.
Share This Page
