clean up camshaft
Discussion in 'Fox 5.0 Mustang Tech' started by ninety1gt, Dec 18, 2007.
  1. ninety1gt New Member
    Aug 27, 2005
    Message Count:
    164
    san antonio
    i recently bought an e303 camshaft with what the guy said 200 miles. it has little rust and was wondering if this will affect the engine, how can i clean it up? i was thinking with some 3000gr sand paper and mothers polish. any help? will post pics if needed
  2. 91 HATCH Banned
    May 17, 2007
    Message Count:
    271
    illinois
    any pics and what are the numbers on the end of it
    Sponsored Ad
  3. samickguy15 New Member
    Sep 1, 2005
    Message Count:
    403
    Delavan, IL
    If it's just super light rust, don't worry about it. Hit it just enough to get the rough stuff off and stick it in. I wouldn't hit it with a polishing compound of any sort, only a clean rag.
  4. tmoss Gettin Wired
    Jun 28, 2001
    Message Count:
    7,114
    78
    Saint Louis, MO
    if you want to take the time, set up an electrolyte cell in a bucket that has a fair amount of baking soda in the water. Apply a battery charger - one side to the cam in the middle of the bucket, and one side to metal or foil draped insdie the side of the bucket. Let it sit for a few hours or a day (or more depending on the amount of rust) and it will be clean.
  5. PUNISHER RACING Active Member
    Aug 28, 2007
    Message Count:
    1,234
    36
    FORD CITY, PA.
    steel wool and wd40 or diesel fuel
  6. Foxfan88 My Grandpa has great wood.
    Sep 13, 2004
    Message Count:
    2,516
    Miami, Ok
    get some fine emery cloth, will polish it right up
  7. vristang Advanced Member
    Mar 31, 2005
    Message Count:
    4,698
    66
    Seattle
    If it were me???
    ebay it (disclosing its condition)
    and buy a NEW cam...
  8. Fast63 New Member
    Sep 20, 2007
    Message Count:
    717
    Mark me down for this one!
  9. 65ShelbyClone Founding Member
    Sep 9, 2000
    Message Count:
    4,562
    66
    Antelope Valley, SoCal
    +1
    Suppose you use a doctored-up cam and it takes out the lifters later. In the process of trying to save $150, you've just wrecked ~$300 in parts.
  10. oz Founding Member
    Jun 29, 2000
    Message Count:
    959
    Plymouth, MI
    If money is no object, replace it.
    Before you install it, use a micrometer to make sure the lobes aren't worn. I bought an Edelbrock cam from a friend. He got it out of a 302 boat motor that had only been run a few hours. When I measured the lobes I realized that a couple of them were shot. They guy that had the boad before must not have broken in the cam correctly and fried a few lobes. I ended up buying a new one.
    Assuming the lobes are in spec and not super pitted from the rust - super fine steel wool and WD40 sounds pretty good. I would not polish it, you just need to remove the surface rust.
  11. lang williams New Member
    Jun 12, 2003
    Message Count:
    572
    cleveland, oh
    i've had good luck with the scuff pads or scotch bright pads an wd 40.
Share This Page
