Cleaning Convertible Top
Discussion in '2005 - 2009 Specific Tech' started by supermanjcttu, Dec 31, 2008.
  1. supermanjcttu New Member
    Dec 3, 2008
    Message Count:
    What kind of cleaner do you guys use on your convertible top? More importantly what of liquid or finish can I use to restore the factory black color to the top? Thanks for the help.
  2. btorlv New Member
    Apr 8, 2006
    Message Count:
    18
    I have a 06 and the top looks better then new. I use ragg top comes in a kit with cleaner and dressing. Found it at autogeek and i still have the same kit from 06. My top looked sort of gray when i first got the car and know its more of a nice black finish.
  3. wusthof Member
    Nov 20, 2007
    Message Count:
    190
    BC, Canada
    I use the same. It does a nice job, but i'm also gunna try to find a cheaper alternative. depending on your climate, it should last you a while
  4. TPony Member
    Aug 3, 2006
    Message Count:
    88
    Aldie, VA
    Ragg Top is the one I use.
  5. CaliSpecial New Member
    May 24, 2008
    Message Count:
    18
    Essex, England
    Yep, me too on the Ragg Top. Make sure you get the correct one though! (Vinyl or Cloth) :)
  6. stanmckinney Active Member
    Mar 31, 2005
    Message Count:
    1,180
    38
    Dumb question. How can you tell if your top is cloth or vinyl? I have a 1966 and I don't know which it is.
  7. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    7200 feet
    if it is hard and smooth, its vinyl. cloth tops are softer, and appear "cloth" like. check out some higher end cars as they usually have cloth tops.
  8. shelby69 New Member
    Mar 20, 2002
    Message Count:
    100
    allentown
Share This Page
