Cleaning Headlights
Discussion in 'Mustang Sound & Shine All' started by 2003BlackStang, Aug 16, 2005.
  1. 2003BlackStang New Member
    Nov 11, 2003
    Message Count:
    233
    What is the best way to clean headlights? I always clean mine with glass cleaner after i wash the car but there is still always spot on it no matter how hard i try to get them off what can i try?
  2. 94GTMOOSE Member
    Jun 28, 2005
    Message Count:
    300
    jersey shore
    try compounding them. i use 3m liquid compound. you could do it by hand, but a highspeed polisher works best. BUT DO NOT OVER DO IT WITH THE HIGHSPEED POLISHER. you could get it so hot that it melts the plastic. I like to get a little squirt bottle of clean water and spray it on there ever couple of seconds.
  3. 2003BlackStang New Member
    Nov 11, 2003
    Message Count:
    233
  4. KronicRacer New Member
    Jun 24, 2004
    Message Count:
    502
    puttering around Ft Lauderdale, FL
    any recommendations for the hazy head lamps?
  5. davematthews112 New Member
    Nov 24, 2004
    Message Count:
    9
    Maquires or whatever makes a compound that is suppose to get rid of the hazy/yellow look on headlights. We use it at work, and it does make a difference.
    -Drew
  6. Mustang4119 New Member
    May 26, 2004
    Message Count:
    170
    Mothers plastic polish.
  7. Twilight Blue New Member
    Aug 3, 2005
    Message Count:
    56
    I'd say just trash them. There are plenty of replacement headlights out there from suppliers like 5.0 Resto that will be better than the factory originals as far as being resistant to turning yellow and milky. I like the ultra clear headlights. They are similar to the 1994-1998 Cobras. However, if you have to keep the old ones like me, try an obital buffer with some compound. It won't get rid of the yellow, but it will be clear and not so milky. Touch it up with some Eagle One trim restore.
  8. Roland69 Sergeant Tangnet
    Sep 17, 2005
    Message Count:
    3,102
    58
    Port Elgin, Ontario
    I took my headlights out and polished them using my bench grinder with the buffing wheel and some aluminum compound. They now almost look like new. be carefull not to burn the plastic but it takes more to burn them than I thought it would.
  9. glowstang93 Member
    Feb 9, 2003
    Message Count:
    822
    Illinois
    Do what you can afford, but new ones are worth the money. It is really amazing how much it improves your headlights and the looks too.
Share This Page
