cold air intake
Discussion in '94-04 V6 Mustang' started by 03silverv6, May 30, 2006.
  1. 03silverv6 New Member
    Feb 4, 2006
    Message Count:
    44
    about 6 or 7 months ago i bought a cold air intake from mustangtunning.com i ahd trouble installing it so brought it to a garage and they put it in. the pipe that attaches to the engine had a hole in it with a lil piece of rubber around the edges but was open and the guy said to leave it open. is this right? shoudl this be open? is unfiltered air goin in? is that bad for the engine?
  2. TMX New Member
    May 24, 2005
    Message Count:
    225
    unfiltered and unmetered air can cause it to run rough and if something big finds its way in there, that wouldn't be good. I believe the hole that you are looking at is for the IAT sensor which is on 99-00 Mustangs, but on 01-04, the IAT was integrated into the MAF. You would have to find a way to plug the hole and put some silicone around it to seal it good.
  3. OxMox turkeysammichesonhisface
    Mar 31, 2005
    Message Count:
    611
  4. 03silverv6 New Member
    Feb 4, 2006
    Message Count:
    44
    mine is an 03. so do u think that is not right
  5. TMX New Member
    May 24, 2005
    Message Count:
    225
    well, it's the 99-04 series CAI, so it just comes with the IAT hole, it's just your 2003 does not have the IAT sensor to go there.
    "But even in the 99+ years, there were changes to the design of the stock induction system. 99-01 V6 Mustangs have a seperate sensor for temputure, thus incorperating the temputure sensor hole in the MAF to TB tubing. While the 02+, redesigned the MAF itself to incorperate the temputure sensor inthe MAF housing. Thus making the hole for the temp sensor an obsticle to overcome for the 02+'s. If you wish to put a 99+ CAI onto your 02-03, you will need to come up with a way to plug up the hole. Some have gone to an automotive chain store, purchased a rubber grommet to plug up the hole. One person in particular used a bicycle valve cap and silicone to plug up the hole. Quite creative. He has yet to report any problems with this method."
    http://www.asbclan.com/rellik/cai.html < a nice CAI article with a long, but good, FAQ.
  6. 03silverv6 New Member
    Feb 4, 2006
    Message Count:
    44
    is it bad if i leave it open. also the guy who put the intake in said it is bad to plug it up. i dont know what to do. i have looked at other intakes from other sites and they too come with the hole so i didnt buy i bad one.
  7. TMX New Member
    May 24, 2005
    Message Count:
    225
    Plugging it is not bad. By leaving the hole open, the engine starts to pull in air that is not measured which makes you run very lean. Leaning out a car leads to pre-detonation which is damaging to the engine, a bad detonation could lead to a rod going through the oil pan. Not to mention if a small pebble gets through the hole and could knock against your valves, and if it makes it into the chamber, damage the valves and pistons.
  8. 03silverv6 New Member
    Feb 4, 2006
    Message Count:
    44
    so what do you guys think i should use to plug it up and where can i get it?
  9. TMX New Member
    May 24, 2005
    Message Count:
    225
    Check if the local autoparts store has a rubber grommet that would fit and cover the hole, or if they don't, someone has used the valve cap from a bicycle tire, put it over the hole and used a slicone sealant to keep it there. He hasn't reported any problems with his fix either.
  10. 03silverstang New Member
    Jun 2, 2004
    Message Count:
    123
    not to be repetitive or question you guys because you guys give a lot of valuable info but you are sure that is will not hurt the engine by pluggin it up?
  11. 03silverstang New Member
    Jun 2, 2004
    Message Count:
    123
    i do not meen to be repetitive or question you guys becasue you guys give a lot of valuable info but you are sure that it will not hurt the engine by pluggin the hole up?
  12. TMX New Member
    May 24, 2005
    Message Count:
    225
    Well, you figure on the 99-01 models (I have a 2000), the hole is plugged by a sensor. For the 02-04 years, that sensor was included with the MAF to simplify things, but this leaves that sensor hole open. Leaving a hole past the MAF is always a bad idea because the engine will pull the air in the fastest way possible, and when this happens the MAF cannot meter the air that comes in through the hole because the MAF is before it. If the MAF cannot meter the air, the ECU will not put enough fuel into the chambers leaving you running lean, and since the MAF and O2 sensors will show different readings, it will only throw a code and make the engine run bad. Too lean causes extreme heat inside the combustion chambers and can lead to pre-detonation. The heat can melt pistons and pre-detonation can cause unwanted stress on the rods, eventually possibly causing failure. MAC, BBK and K&N all include a gromet to cover this hole for 02-04 years or they do not have the hole at all.
  13. V6muscle00 New Member
    Apr 12, 2006
    Message Count:
    97
    isnt that unplugged hole causing a vacuum leak? or is that vacuum only created inside the throttle body? i just found it weird that u havent heard any high pitched whistling :shrug:
  14. 03silverv6 New Member
    Feb 4, 2006
    Message Count:
    44
    no i dont hear any whistling as far as i can hear. do you think it is better i buy one from MAC or plug it up cuz i would rather spend the money than go cheap and hurt the car
  15. Roland69 Sergeant Tangnet
    Sep 17, 2005
    Message Count:
    3,102
    PLUG THAT HOLE...do you think unfiltered air is good....no you mite as well be running no air filter at all
    Not trying to be a dick but would anyone run thier car without a filter
  16. Roland69 Sergeant Tangnet
    Sep 17, 2005
    Message Count:
    3,102
    is the pipe aluminum if it is take it to someone with a TIG welder and see if they can plug it with some aluminum fill rod. and then you can smooth it and polosh it and you would hardly be able to tell there was a hole there in the first place. The welder should only charge you 20-30 bucks....Or even wrap some tape around the tube for now. Heck even use bubble Gum lol
  17. 03silverv6 New Member
    Feb 4, 2006
    Message Count:
    44
    there is a grommet in there it just has a whole in it. im am not questioning you guys just lettin you know. it is not the big whole that is in the pipe but a small one.
  18. 03silverv6 New Member
    Feb 4, 2006
    Message Count:
    44
    also another question u v6 guys who do not have the temp sensor. did you have the sam problem or did you buy one that came with something to plug it up with. let me know because i would rather get a new one. also the MAC one looks like it has the some thing or am i wrong. u guys r the best thanx for all the help. hopefully i can fix this soon
Share This Page
