compression test
Discussion in 'SVT Forum' started by CT97SVT, Nov 14, 2004.
  1. CT97SVT New Member
    Feb 1, 2004
    Message Count:
    17
    what should i expect for compression test numbers out of my 97 cobra???? so far i havent really gotten a definitive answer from anyone. i have numbers anywhere from 135 to 160 on the motor with 98k. is this ok or just barely ok??? guess im just tryin to decide if i should pull the motor yet and do a full rebuild. thanks in advance to all who reply.......
    steve
  2. tygr1 New Member
    Jun 17, 2004
    Message Count:
    327
    SoCal
    If those numbers are good ones (no leaks), then you are a candidate for a rebuild. The numbers themselves aren't so critical (160 psi is ballpark normal for 98k), but the differences between each cylinder are.
    A difference of more than 10% from any cylinder to any other shows some excessive and uneven ring/cylinder/valve guide wear, worse in some cyls than others...this will only get worse from here on out.
    You may have many, many miles left, but you are exacerbating the problem every time you drive it hard. Not to mention the fact that you'll be down on power in the 'bad' cylinders.
    160 psi times 90% would be 146 psi. This would be a GOOD used motor's range of compression.
    160 vs 135...it's just getting a little tired, that's all...HP will gradually slip away.
    Hope that made some sense. Someone smarter will come in behind me, don't worry
Share This Page
