Considering Cams
Discussion in '2005 - 2009 Specific Tech' started by Sanctus, Jun 22, 2006.
  1. REDFIRE 05 GT New Member
    Nov 18, 2004
    Message Count:
    284
    Junction City KS
  2. Pro Mod Member
    Nov 17, 2005
    Message Count:
    238
    Wharton, WV
    the Comp Cams still work with the VCT, but you still have to remove & reinstall the VCT stuff to get the cams on.
  3. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    7200 feet
    thats what i meant.
  4. Pro Mod Member
    Nov 17, 2005
    Message Count:
    238
    Wharton, WV
    yeah I could tell that's what you meant :nice: , I just think Redfire misunderstood ya :)
  5. "car"azy New Member
    Oct 21, 2004
    Message Count:
    40
    i had cams pistons rods heads everything done on mine at boss 330 and champion racing heads it sounds mean and pulls real hard to 7200 it put down 360 na 355tq on a realy hot day that took an hour to get to
  6. creedog New Member
    Nov 15, 2003
    Message Count:
    60
    [QUOTE="car"azy]i had cams pistons rods heads everything done on mine at boss 330 and champion racing heads it sounds mean and pulls real hard to 7200 it put down 360 na 355tq on a realy hot day that took an hour to get to[/QUOTE]
    All I can say is "WOW"! Everything I have heard about boss330 has been A++++, topnotch, none better. Can you give us any more details? Is the car more for just the straight line track, or is the car daily driveable/dependable? Any ballpark figures for costs? Any other mod's needed to handle the extra power? What cams, pistons, and rods? Any tuning issues, and such?
  7. "car"azy New Member
    Oct 21, 2004
    Message Count:
    40
    im very happy with the work i had done at boss 330 and the head work at champion racing heads they put together a great combo that was designed for the drag strip but my wife can still drive it, so yes it very streetable. i plan on spraying a 175 to 250 shot depending on tunning etc. so far with the diablo tune it hasnt had any problems, im sure with a large shot that could all change! if your happy with 400 at the wheels a blower is more cost effective unless you are unlucky or abuse it then you will be rebuild anyway. thats why i did mine rather than sending pistons, rods, valvetrain into a grinder, then theres a lot of machine work and even more money.
  8. wannarun New Member
    Oct 17, 2005
    Message Count:
    9
    oklahoma
    Is there any issues with low manifold vacuum @ idle? I hate to ask, but how much fuel mileage did you loose?
  9. "car"azy New Member
    Oct 21, 2004
    Message Count:
    40
    havent noticed any vacuum problems and in town i get 18 mpg 21 hwy thats with a 410 gear, i would like to go 430 (na) to keep it up in its power band but im sure that would be to much on spray
  10. GTRacerX New Member
    Sep 17, 2005
    Message Count:
    30
    Miami FL
    Anyone have a vid of Stage II or III here ?
    Is Blow by Racing using Comp Cams? There vid sounds violent !!!!:nice:
  11. stlwagon New Member
    Oct 16, 2005
    Message Count:
    15
    Southern, MD
    I did the stage 1 cams a few weeks back. Not too agressive but sound nice.
  12. Pro Mod Member
    Nov 17, 2005
    Message Count:
    238
    Wharton, WV
    stlwagon, did you do the cam install or take it to a shop? I've helped with a cam swap in a 2V, but what does the VCT add to the complexity of swapping the cams? Did you see a noticeable difference in power with the Stage 1 cams?
  13. stlwagon New Member
    Oct 16, 2005
    Message Count:
    15
    Southern, MD
    I had a local guy do it since I don't mess with the internals. He said it was quite a challenge. Didn't get into specifics.
  14. creedog New Member
    Nov 15, 2003
    Message Count:
    60
    Ok, can you give us some more details? Do you have a video? Increased hp/tq #'s if available? Tuning,what about tuning? Any tuning issues or concerns?
    Ok, I just read your final hp/tq #'s on your sig. Nice
  15. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    7200 feet
    BBR uses their own cams which are reground stock cams. they may finally have billet cores that have made their way into production. i have not followed BBR since their false cam claims a while back.
  16. stlwagon New Member
    Oct 16, 2005
    Message Count:
    15
    Southern, MD
    Those #s were right after I had the cams & LTs done. Adding the LTs really threw off my A/F so I was still running a bit lean. I think my numbers might be a little higher now but I haven't dyno'd it again yet.
  17. Pro Mod Member
    Nov 17, 2005
    Message Count:
    238
    Wharton, WV
    stlwagon, did you buy the cams somewhere and then take them to the shop; or did you buy the whole setup from the shop? I'm trying to find the cheapest place to guy a set of those cams & valvesprings.
  18. stlwagon New Member
    Oct 16, 2005
    Message Count:
    15
    Southern, MD
    Purchased from RPMOutlet and had a local mechanic/speed shop do the work. Didn't do the springs. It is required for the stage 2-4 cams.
Share This Page
