tweet66 said:
302coupe, I'll try some bigger jets and I'm going to replace the PV while I'm at it. I've been noticing alot of surging at all types of throttle application. Last time I had that on my 74 Bronco with a 1850 Holley the PV went a day later.
One thing at a time, otherwise you'll have a hard time learning anything about your carb. Change the PV to something closer to your cruise vacuum readings since you're already way off. You mentioned that it accelerates fine under light throttle, that means the jets are doing their job. Once you get into it, the vacuum signal drops, and the PV
should open, letting in the extra fuel it needs. If your signal drops but your PV doesn't open then you get a lean condition, which is felt with a stumble.
Surging at cruise can actually mean that your jets are too
big, and your engine is loading up with the extra fuel until it is burned up.
Do one test at a time when reading plugs. To check jetting, drive at steady-state throttle for as long as you can before pulling them.
Stay off the power circuit as much as possible or this will foul up your readings. This way your plugs will tell you if your jets are too rich/lean.
You mentioned your plugs read a little lean, but was that from light acceleration testing, steady-state driving, or full throttle? Or all of the above? One test at a time, especially if you're going by smell, your butt-dyno, and plug readings.
I'd suggest for anyone with a carb to invest in an air/fuel ratio (AF) meter. You will learn tons of things about your carb with an AF meter installed, and just carbs in general. The guys with "perfectly tuned carbs" will be surprised on how far off they are with an AF meter installed. Not to mention the time you save from constantly pulling plugs and playing guesstimate with a box full of jets.
