you can get pretty much any dizzy you want, all the major companies make one, MSD, Mallroy, Accel, Pertronix or even just a stock replacement from the local parts store. you don't have to get the one specified for the 289, a 302 dizzy is the same. definitely get rid of the dual advance and IF possible you can ditch the PVS as well, however be aware that to get rid of the PVS you need a carb that has a ported vacuum port, most 4100 ford carbs don't have one and some holleys don't either, so be careful there. if you have the right carb you can ditch the PVS and get a different thermostat housing as well. most of the replacement therm housings have a port for the PVS and just have a plug in the box to plug the hole. the chrome therm housings don't have a spot for the PVS but they all leak like hell, so avoid those if possible. you can order a stock style therm housing from most of the Mustang parts places that doesn't have the provision for the PVS but it's for the early 289 and uses a different bypass than your 68, although you have to change the bypass hose this is the route i'd recommend. if you really like the look of the chrome therm. housing you can always polish the early 289 unit i mentioned since it is made of aluminum.
