does it get any easier
Discussion in '2.3L (N/A & Turbo)' started by blastit116, Jan 17, 2004.
  1. blastit116 New Member
    Oct 4, 2003
    Message Count:
    178
    jupiter,florida
    today i went to go change spark plugs and started on the right side of the engine removed the air and i got to change all 4 plugs so go over to the left and i relize that it looks like i am going to gave to remove the air intake and maybe the altenator is there any way to remove with out taking all that stuff off
    thanks
  2. mr_woodster Active Member
    Jul 28, 2003
    Message Count:
    1,316
    36
    Riverside, CA
    so you have a v8 right? 8 spark plugs means faster! :rolleyes: (the joys of dual plug heads :doh: ) I would try using a swivle sparkplug socket, should be able to get them out ...
  3. blastit116 New Member
    Oct 4, 2003
    Message Count:
    178
    jupiter,florida
    sounds good going to try tomarrow
  4. 85 Coupe 5.0 Founding Member
    Dec 18, 2001
    Message Count:
    815
    Kansas
    I had to use a swivel and a 6-inch extension on my girlfriends '96 Ranger. I also put a piece of vacuum tubing on the end of the plugs when i started them into the hole, as it is VERY easy to cross-thread them on the intake side. Other than that, piece of cake.
  5. Pro-Hawk New Member
    Dec 5, 2003
    Message Count:
    990
    West Texas
    I feel your pain :( I just did the exhaust and about to do the intakes my self, maybe that valcumm tube idea will help out some with my swivel and 6"ext. Tomorrow I will go down and get a pice and maybe a pair of wire boot pliars , my hands are to big to get a good grip on some of them wires. The DP is the one thing I want miss once my TC motor is done :)
    I will say this, just replacing the exhaust plugs helped smooth out the car a lot for me.
  6. Pro-Hawk New Member
    Dec 5, 2003
    Message Count:
    990
    West Texas
    Well I finnaly got the intakes side done. I used a wire boot pliars, 12" 3/8 ( Thanks 85 coupe 5.0) vacuum tube, 6" ext, 3" ext and a swivel plug socket.
    Now the first two was pretty easy even the altinator one using this stuff. The valcuum tube helped a lot, now on the last two I stuck a 6" 1/4 ext in the tube to help it stay straight and not curved. On the last two it made it a lot easier to use a 6" ext along with a 3" ext ( unless you got a solid 9" or so ext which I didn't). Now that last one on the intake next to the fire wall was a real pain until I unpluged the EGR plug and the vacumm line on it. If you do this and use the plug wire pliars it helps a lot. I hope this will help anyone having to change plugs on a DP 2.3L ;)
  7. i4power Founding Member
    Jan 11, 2002
    Message Count:
    1,096
    Eglin AFB, Florida
    I changed all the plugs on my car without having to touch anything else. It must be because i'm an F15 mechanic, and those things seem like they were designed to be hard to work on ON PURPOSE.
    Oh, and yeah I used a swivel piece on a long extension. It helped a TON.
  8. Pro-Hawk New Member
    Dec 5, 2003
    Message Count:
    990
    West Texas
    Only thing I had to do was unplug the EGR which took 5 seconds to unplug and plug back, no biggy. I guess if I had a skinnyer set of pliars or smaller hands I probly could have done it without unpluging the EGR. You need any help on the F15 let me know I watch Monster Garage so I know how to do jets :D
    Its all about the right tool for the job on the 2.3L DIS DP cars thats all.
  9. blastit116 New Member
    Oct 4, 2003
    Message Count:
    178
    jupiter,florida
    well like i said the right side is easy its the left thats a pain but i never got around to it this weekend instead i just did the headliner so next weekend this is what i will be doing also the tubing is a great ideal so thanx for all the help
    ps I also watch Monster Garage so I know how to do jets but this still is a pain in the ass
  10. Pro-Hawk New Member
    Dec 5, 2003
    Message Count:
    990
    West Texas
    Also try the part on disconnecting the EGR eletric plug and the vacuum line, once thats done you should have a little more room to tug on the plug wire.
    ( use the boot pliars to tug though)
    Good luck
Share This Page
