Driveline Vibration when I start moving. (T5)
Discussion in 'Fox 5.0 Mustang' started by DARCA, Oct 29, 2009.
  1. DARCA New Member
    Nov 20, 2008
    Message Count:
    62
    In first or reverse when I get about half way off the clutch I get this ruff vibration I can feel coming through the car. Anyone know what this could be?
  2. earleys94gt Member
    Aug 31, 2003
    Message Count:
    823
    Worn out u-joints maybe?
  3. pudman Member
    Jun 1, 2008
    Message Count:
    111
    could be u-joints or tranny mount
  4. Lawbreaker5.0 New Member
    Feb 21, 2009
    Message Count:
    537
    clutch chatter
  5. DARCA New Member
    Nov 20, 2008
    Message Count:
    62
    I'll take a look at the tranny mounts and U-Joints on Friday. I haven't felt anything like this since I got it a year ago and I Romp and Stomp on it not everyday but fairly often.
  6. DARCA New Member
    Nov 20, 2008
    Message Count:
    62
    Explain "Clutch chatter" if you wouldn't mind too.
  7. ID89GT Active Member
    May 26, 2008
    Message Count:
    1,532
    38
    +1
  8. DARCA New Member
    Nov 20, 2008
    Message Count:
    62
    Clutch has been solid for well over 30K miles. And don't slip shift, power shift, grind, or shift hard at all. I ride her hard when shes in gear on the occasion but I baby the tranny as much as possible. Clutch is FRPP King Cobra clutch btw.
  9. Mustang5L5 Founding Member
    Feb 19, 2001
    Message Count:
    19,541
    78
    It sounds like clutch chatter.
  10. DARCA New Member
    Nov 20, 2008
    Message Count:
    62
    Mind explaining "Clutch Chatter" ...
  11. Lawbreaker5.0 New Member
    Feb 21, 2009
    Message Count:
    537
    all i know is that it chatters going into first and reverse. the whole car shakes. i had a good website that explains causes of chatter, like oil on the clutch, wrong pinion angle, u joints. . .etc.
  12. Mustang5L5 Founding Member
    Feb 19, 2001
    Message Count:
    19,541
    78
    Clutch chatter is basically the clutch skipping across the flywheel when you slip the clutch. There are a bunch of different factors that cause it, and any clutch can do it.
    Basically just google search clutch chatter and you'll find more info.
    This is clutch chatter right here
    YouTube - Clutch Chatter
  13. DARCA New Member
    Nov 20, 2008
    Message Count:
    62
    In that video there was a lot of noise I noticed when it happened. Whats happening in mine is slight and more of a grinding (It feels a lot like putting sand between ur hands and rubbing them together if that makes any sense.) vibration. Its quite and not as noticeable as what was happening in the video. It only happens in 1st and reverse and it fads really quickly.
  14. Mustang5L5 Founding Member
    Feb 19, 2001
    Message Count:
    19,541
    78
    Failing throwout bearing?
    Without being there, it's tough to diagnose.
  15. DARCA New Member
    Nov 20, 2008
    Message Count:
    62
    Its kool, Thanks for all the input though!
  16. 95BlueStallion Member
    Feb 23, 2007
    Message Count:
    860
    18
    You might look at your brakes for a seized caliper, or sticking drum. I know Im way off base from the others, but first and reverse are the only gears where you are moving the car from a stop, and your brakes could be grinding a bit... It may not be noticeable once the car is moving due to road noise, etc.
  17. DARCA New Member
    Nov 20, 2008
    Message Count:
    62
    Awesome! Thanks for that, cause my car is gunna be on a lift tomorow as is so I'll just pop the wheels off an check out the brakes!
  18. SMOKEDYA Well-Known Member
    Jul 13, 2003
    Message Count:
    3,604
    56
    my 4 banger with a t5 did simaliar to this i thought it was the trans? nope! clutch? nope again! then i replaced the driveshaft with an alum one. problem fixed! then i noticed while the drive shaft was out of the car the front u joints were sooooo soooooo shot i was like :jaw: how the hell did it even stay together!peace
    john:p
  19. DARCA New Member
    Nov 20, 2008
    Message Count:
    62
    Haha I was actually seriously about to order an aluminum drive shaft. Haha.
  20. Lawbreaker5.0 New Member
    Feb 21, 2009
    Message Count:
    537
    when you say shot. how bad were they? the only way i know how to check u joints is by rotating them and if they feel rough or choppy as you turn then they're bad. is there another way to check them that i don't know of?
Share This Page
