Driveshaft
Discussion in 'SVT Forum' started by Morpheusgpr, Mar 30, 2004.
  1. Morpheusgpr Founding Member
    Jan 29, 2002
    Message Count:
    257
    Ok so I hear the driveshaft needs to be updated with gears. Who makes one that is the right size for the 2001 Cobras? I don't want to screw anything else up.
    I don't have the gears yet but would like to get the shaft done in anticiaption for it. It will reduce some vibration and mass for now anyways.
    So who has them and what is a good price on one. Whats the install going to run me roughly and anything else I should get done while its being installed...new bushings of some sort?
    Thanks.
    p.s. who makes a good driveshaft loop that is not going to require me to chop up my underside just to install it.
  2. SVTdriver Founding Member
    Sep 2, 2001
    Message Count:
    3,425
    I have never heard of having to change driveshafts at the same time you change gears.
  3. COBRA90GT Moderator
    Sep 22, 2001
    Message Count:
    6,832
    86
    Yeah, you don't *have to* swap out the driveshaft. But, it's a very common upgrade (switching to the lighter aluminum shaft).
    BTW - Since you have an IRS equipped cobra, you might want to bookmark & read through the following site just in case (LoPony's drivetrain vibration page):
    http://home.hiwaay.net/~ctfrench/Driveline Vibration.htm
  4. AzDropTop Founding Member
    Mar 11, 2001
    Message Count:
    138
    I have heard the FMS shaft is resonably priced but needs to be modified a bit-1.5"s I think? Others have used the 98 Cobra shaft and modified it as well...
  5. 99SVTAddict New Member
    May 8, 2003
    Message Count:
    643
    Find a reputatble shop that can make and balance a custom driveshaft.
    That's what Alternative Auto did for my car.
    I've had 4.10's in the IRS, now 4.30's in the solid...no vibe at all.
  6. Morpheusgpr Founding Member
    Jan 29, 2002
    Message Count:
    257
    Is the DS from STEEDA a good choice? Its 175 on their site.
    Will it fit without being modified or does it need some retro fitting?
    Also how is their drive shaft loop...any others that are better?
    Another consideration of mine was the tranny cooler...should I get one?
  7. aprather New Member
    Mar 6, 2002
    Message Count:
    38
    [IMG]
    I just got mine in from Steve at Houston Performance www.houstonperformance.com
    It was $166 shipped and cheapest I could find anywhere. Might wanna give him a call to see if he has any others in. He didnt think he had any in when I called, but found 1 in his warehouse, he may have some more though. Tell him Aaron sent ya :)
    Anyway, I havent heard of anything needing to be modified to make it fit, but I will find out this weekend.
    On edit: I guess due to the IRS, you do have to modify it somehow. Im glad I have a GT :D
    Good luck.
  8. SloCobra New Member
    Feb 8, 2004
    Message Count:
    34
    Gene Evans Ford is also pretty cheap on their Ford Mororsports stuff.
Share This Page
