Yes, the settings are in TS. I will get a screenshot
Laptop is dead will get it for you later.
... are we sure it's working right? The ecu doesn't turn it on in our application.
I need to do this too. I need to build a separate circuit that'll trigger a dedicated small fan that I'll mount on the condenser, and trigger the FIDLE valve when the car gets below a certain RPM (like at idle) and I turn on the AC.I do know my diypnp would require me to build a circuit for this setup. A relay in the system to pull low when the tps goes above x tps signal. Then wire that to pin 54, pretty simple for me.
I'm not sure about the mspnp2 one would think that it's already there built in and maybe the output is pulled low from something in the tune parameters (would have to be or the circuit would be open). Send me a current copy of the tune file, it's in there somewhere..... you have alot more i/o options than I do.
You can do it that way for the fan wiring no problem. Only question is the wot relay..... don't want the compressor on when boiling the rear tires....I can never read that schematic..The Transistor wiring diagram always makes zero sense to me.
If I use my ac control switch as a "trigger" ( the one that turns on the compressor) why can't I just add a relay to power the fan from that same circuit? Isn't there some output condition on the MS II that I can set to turn on the FIDLE valve at some point through the existing build before I go opening this thing up again and creating another hideous mess of my "at one time" pretty circuit board?
it's the only thing I'm good at.a91what has done it again. He is always right when it comes to this.
The schematic in my service manual was wrong. The AC pnk/ Lt blu signal wire runs to pin 10 on 89- 90 v8 mustangs. Pin 54 org/ Lt blu should have 0v koeo and koer w/AC on at idle should be b+. My MS supplies ground when ac is cut on...in turn activating ac WOT cut.
Here's a video...as promised....
View: https://youtu.be/VG_7KrNFY5Y
Dang private roads...no flat spot around here. No one will get together to help strip and pave the road. Smh
No Data log yet...its coming...
