Well, lets see, my brake lights stay on..always. As do my instrument cluster lights, and dome light. And now to make things worse it will not shut off...at all. Starts fine, turn the key off and it stays running. This isn't it dieseling as there is NO change in anything when I take the key out.
Are these three different problems, or do you think they are all related? What do you think is causing it?
I'm wondering if it isn't just time to re-do all the wiring, I hope not though, not looking forward to that.
It has an HEI distributor in it, and the engine is a 68 302.
Resistor wire that used to run from the original coil to the ignition switch has been replaced with a wire that delivers 12v instead of the 8 or whatever.
The brake lights have been giving me this problem for about 1 year. The dome light/instrument cluster lights only started last fall when I parked it for the winter.
It staying running has only been like this for 3 days now.
And did you replace the flasher?
