Engine Bay cleaning and detailing?
Discussion in 'Mustang Sound & Shine All' started by BOSS4.6L, Aug 12, 2005.
  1. BOSS4.6L New Member
    Apr 10, 2005
    Message Count:
    63
    Hey I was wondering what would be the best technique to cleaning the eng bay, I live In the great "Dust Bowl" of Pheonix Az and I have no problem with a little dust in the eng bay but when it rains here it turns to mud(sorta!). I have been told to just spray it off, but atleast cover up the intake/throttlebody, and the Battery. I am worried that I could screw up the electrical components if I spray it. Does any body have and sugestions? thanks
  2. WhiteHeat306 New Member
    Nov 28, 2004
    Message Count:
    305
    Before you spray down your engine and degrease it, I suggest covering the electrical components with plastic bags. Then start up your car and spray the degreaser, let it sit for a minute or two, then hose it off. If it's your first time, maybe break down the engine into thirds and do each section at a time. After you're done degreasing, spray some tire shine onto the engine, then wipe off the excess....it will look better than new.
  3. durknutz01GT New Member
    Jul 5, 2005
    Message Count:
    i didn't cover anything. coated it with Simple Green, waited a few, and sprayed it down using a very low pressure mist. Unfortunately, this was my first time doing it (got these tips from a friedn), so I may have doushed the engine a little too much. car misfired like a bastard, but after giving it enough time for the moisture to dry out, it's fine again. still have a cyl3 misfire so there could be some lingering moisture. looks great and runs like normal again...
    words of advice: use a very low pressure mist, and like whiteheat rec, cover the plugs with baggies. you should be golden. send some pics of your results...
  4. wytstang Advanced Member
    Mar 14, 2004
    Message Count:
    5,154
    76
    Turn the engine on for a few minutes until it is warm to the touch not piping hot. Cover the alt., dizzy, fuse box, or anything else that could be damanged. Use a citruis(sp?) or water based degreaser (they are not harsh to the paint/metals) use a parts brush or old tooth brush to clean. Start from the bottom and work your way up, this helps from spreading grease/grim/dirt that may become attached to your arm. Lightly mist it down till all is removed, leave the hood up for a while to help dry things. Turn it on for a few minuts again to help heat things up so they dry quicker. Then use a water based tire/interior dressing they dry to the touch and not attract dust. A good cheap more importantly water based dressing is Armor all Original. Good luck.
Share This Page
