engine is getting hot
Discussion in '2.3L (N/A & Turbo)' started by Keasbey, May 4, 2006.
  1. Keasbey New Member
    Jun 12, 2003
    Message Count:
    928
    I rebuilt this engine during the winter and finaly get it to run today, I drove it for I would say 10 min, and notice that the temperature needle was around the "R" of normal, and I would say that it's worrying me a bit..
    The A/F gauge was showing a stoich/rich condition
    So except a lean condition, was could 'cause a kind of "overheating" like this?
    Bad timing?
  2. Roland69 Sergeant Tangnet
    Sep 17, 2005
    Message Count:
    3,102
    air in the cooant system did you try burping the system..
    R in the normal isn't all that hot but I don't trust the factory gauges.
  3. Keasbey New Member
    Jun 12, 2003
    Message Count:
    928
    I feel a but stupid to ask that, but how can I burp the system?
  4. Roland69 Sergeant Tangnet
    Sep 17, 2005
    Message Count:
    3,102
    some have a bleeder valve on the highest point on the system that you open and let the air out. But they don't have that on the Fox bodies so you could park up hill and get the rad cap higher than the rest of the system and let it run with the rad cap off an add coolant when if it starts to get low. Squeezing the upper rad hose sometimes helps speed up the process.
  5. Roland69 Sergeant Tangnet
    Sep 17, 2005
    Message Count:
    3,102
    Another method is drilling a small 1/16” hole in edge the thermostat.
  6. rd Founding Member
    Jan 12, 2000
    Message Count:
    3,259
    58
    I would cool it down, remove the radiator cap, and let it run until it warms up. When the tstat opens, it should let some air out, and then you can add more coolant. It may take a couple of tries.
    Also make sure the fan is running....
Share This Page
