engine noise
smpd357sig
For the last 8 months or so my car has been running on a tune that my buddy made using my sct II tuner. Today i got my brenspeed tune and before i loaded it on, i set the car back to stock and drove it around. When i drove it in stock form, at hard exceleration at around 4500 rpms, there is a pinging or sound like something is rolling around in a tin can. It still does it with the brenspeed tune. Im using 91 octane fuel, which is also what the tune is. When i go slowly up to the same rpm range, it doesnt make the sound. Any ideas? should i be concerned
sounds like detonation to me also. That really makes no sense that the stock tune would do that and the custom tune wouldn't. The stock tunes are really conservative on timing and A/F ratio.
Check your owners manual. Sometimes pinging will occur and is normal. Everytime I changed my tune from stock to 91 or 93, it will ping when flooring the gas. However after a few weeks it went away and is fine. Dont know if the computer is adapting or what, but I would also have several other problems which would occur when ever uploading new tunes such as improper gas level, stuck rpm needle, etc. However after a week or so, the car would return to normal. This is from using tunes from SCT.
