I just received a quote from DSS Racing for a 12-secondish car. They have quoted me about $5500 for it. I am not looking to build my own engine, crate is a must. So is this worth the price and will it put out the performance I want on my '69 stang? Thanks!
PRO BULLET FT/IN: 347 cid short block for use with most inline valve cylinder heads andwill accept large cams and large valves. Balanced to racing tolerances and blueprinted,forged DSS Pro Series Pistons, assembled in a Level 10 CNC Block with the billet aluminumMain Support System installed with custom ARP main studs.
SPECS: BLOCK: Level 10 CNC Block- deck equalized and squared, deck plate bored andhoned in CV616 with sub 10 micron filtered man-845 honing oil, and numerous other CNCoperations, RODS: Forged 5.400" Full Floating I-Beams with ARP bolts, CRANK: 3.400"stroke, PISTONS: Forged Pro-X # 4300 (FT/IN -3cc), RINGS: Moly E-458K, RODBEARINGS: Tri-Metal CB-634P, MAIN BEARINGS: Tri-Metal MS-590P CAMBEARINGS: Tri-Metal CC4402,599.952,599.95Track Heat longbl...LONGBLOCK UPGRADE: Final assembly of a shortblock with heads, rockers, and all othernecessaryparts listed below to complete the long block assembly. This critical step in theassemblyprocess is the keyto long life and maximum power. Checking and correcting rockerarm geometry, adjusting pushrod length, and setting lifter pre-load is very time consuming butpays big dividends in power and longevity. These often overlooked steps are included in thislongblock assembly.
PARTS: CYLINDER HEADS: Trick Flow Track Heat CAMSHAFT: Ford Racing TIMINGCHAIN: Pro Gear 3 Position Double Roller 430HDSTK LIFTERS: Ford Racing RETAININGHARDWARE: Hydraulic (when necessary) PUSHRODS: 4130 .080" Wall Seamless HEADBOLTS: ARP 8740 Hex Head Bolts HEAD GASKETS: Fel Pro Graphite 8548 PT2 ROCKER ARMS: DSS Aluminum Roller Rockers T-WASHERS: 1/2" to 7/16" reducerbushings for cylinder heads (where applicable)
Upgrade to premium hyd roller camshaft listed below
Comp Cams XE274HR Camshaft (.555"/.565" 224°/232°@.050" 112°LSA 2200-6200RPM)
