Engine rebuild
Discussion in 'SN95 4.6 Talk' started by mattch2, Oct 24, 2006.
  1. mattch2 New Member
    Jan 21, 2003
    Message Count:
    517
    whats the rough cost on an engine rebuild
    It sounds like i blew a rod, bearings and need a new crank???
  2. BurningRubber Active Member
    Dec 6, 2004
    Message Count:
    2,691
    48
    Depends on how much damage it did as to how much youll need to replace.
    Could have killed the cylinder walls, or damaged the block. If it wasnt bad then you will still need to bore the block over to clean it up, meaning at least new pistons aswell.
  3. mity2 I like Pro3 and all I got was this crappy CT.
    Jul 24, 2003
    Message Count:
    3,299
    i say get VT forged shortblock.
  4. WOT Founding Member
    Nov 26, 2000
    Message Count:
    2,832
    1+ that is what id the easiest thing to do.
    I did rebuild my own and it was pretty easy. But if you don't have the mechanical ability don't bother. I ended up saving about $1800.
Share This Page
