Explorer Help
Discussion in 'Other Auto Tech' started by BurningRubber, Jun 20, 2008.
  1. BurningRubber Active Member
    Dec 6, 2004
    Message Count:
    2,738
    48
    Have a question.
    1997 Explorer, 4.0.
    When the A/C is set on "Max A/C" it works fine, blows cold. When switched to normal A/C or ANY air setting it blasts SUPER hot air, as if someone set the thermostat to all heat.
    Turn the "Max A/C" back on and it works just fine.
    Moving the tempature knob does nothing to change this once the heat is pouring out...
    Any suggestions?
  2. timeless2 Vi Veri Veni Versum Vicus Vici
    Apr 22, 2005
    Message Count:
    10,048
    27
    88
    the Shadow Gallery
    Is the compressor running when the "normal" a/c setting is active? Pop the hood and have someone help you out by toggling the setting between the two (max & norm) for a few minutes each to determine this.
  3. BurningRubber Active Member
    Dec 6, 2004
    Message Count:
    2,738
    48
    I believe that it is, not 100% sure.
    Its been raning the last few days so thats why I havnt checked yet.
    Thanks for the quick reply though, sorry mine was delayed.
  4. timeless2 Vi Veri Veni Versum Vicus Vici
    Apr 22, 2005
    Message Count:
    10,048
    27
    88
    the Shadow Gallery
    Depending on how you answer from here leads us to a few possibilities. I'm no ASE Tech by any means, but here are some preliminary stabs.
    Could be the relay leading from the control unit in the dash.
    Could be the relay telling the compressor to cycle off/on.
    Could be the WOT sensor (compressor) gone awry.
  5. BurningRubber Active Member
    Dec 6, 2004
    Message Count:
    2,738
    48
    Thanks man, it is just annoying to have it set on max the whole time, and cooking yourself if it isnt.
    Ill post back up when I take a further look.
  6. timeless2 Vi Veri Veni Versum Vicus Vici
    Apr 22, 2005
    Message Count:
    10,048
    27
    88
    the Shadow Gallery
    Get it figured out? :)
  7. Darkwriter77 Resident Ranting Negative Nancy
    Jul 1, 2005
    Message Count:
    3,483
    Apache Junction, AZ
    Another idea: If the Explorer uses the same kind of electric blend door actuator motor as used on Crown Vics and Town Cars and such that have that "Automatic Climate Control" crap, those things have been known to do some wacky things by switching over to full-heat when you want full-cold and vise-versa. Otherwise, if it's vacuum-actuated, perhaps you have a disconnected/damaged vacuum hose underneath the dash there somewhere that's in control of your temperature blend door actuator...? :shrug:
  8. Hardtop68 Founding Member
    Aug 23, 1999
    Message Count:
    186
    Puerto La Cruz - Venezuela
    Doing the analogy with a 2000 GT... hot engine coolant is flowing all the time through the heater core... if you get cold air in MAX A/C (I always use MAX A/C) and HOT air on NORM A/C, then the blend door is opening when it is not supposed to do it... on Mustangs there is a vacuum motor for this door... if this were a Mustang, there should be a vacuum line connected to the wrong port on the MAX/NORM A/C knob...
    Has anyone worked around the dash lately?
  9. BurningRubber Active Member
    Dec 6, 2004
    Message Count:
    2,738
    48
    Thanks for giving me some more suggestions.
    This has been on the back burner since shortly after I posted this, but I am going to mark this thread so I can reference back to it.
    We lost a family member and have been trying to deal with that and me nor my dad have had much time to be around the Explorer that needs the help.
  10. timeless2 Vi Veri Veni Versum Vicus Vici
    Apr 22, 2005
    Message Count:
    10,048
    27
    88
    the Shadow Gallery
    Ouch. Take care, man.
Share This Page
