EXternal wastegate question
Discussion in '2.3L (N/A & Turbo)' started by TurboCoupeWHITT, Apr 19, 2005.
  1. TurboCoupeWHITT New Member
    Aug 16, 2004
    Message Count:
    46
    Ashland,Ky
    some of my firneds were debating on how an external wastegate works.... if the waste gate spring on has a 6 psi spring then is that all the boost u can run .. if u are runnin a exteranlly wastegated turbo? someone explain how this works instead of us argueing between oursleves :damnit:
  2. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Wilson, KS
    No, the spring pressure is the minimum boost you can run...then you get a boost controller to run more boost.
    It's the same for an internal gate...ours have a 8-10 psi spring, hence the reason we can't run less than that on our cars.
  3. Turbopit New Member
    Oct 8, 2002
    Message Count:
    47
    Colorado Springs
  4. mr_woodster Active Member
    Jul 28, 2003
    Message Count:
    1,316
    36
    Riverside, CA
Share This Page
