forged internals?
Discussion in '2.3L Mustang Talk' started by t3-svo, Oct 31, 2005.
  1. t3-svo New Member
    Apr 19, 2005
    Message Count:
    76
    which years did the svo come with forged nternals from the factory. And which internals were forged? also what were they made of.
  2. Sonicpony New Member
    Dec 12, 2004
    Message Count:
    92
    thats a good question
  3. Dan P. Founding Member
    Apr 27, 2002
    Message Count:
    477
    26
    All years, the pistons are forged and they are aluminum
  4. 79'293stang Active Member
    Jan 6, 2003
    Message Count:
    413
    28
    as far as I know the svo's came with forged rods, pistons and a cast crank.
  5. mr_woodster New Member
    Jul 28, 2003
    Message Count:
    1,316
    Pistons were forged
    Rods powdercast (not forged)
    Crank cast-iron
    :Word:
  6. t3-svo New Member
    Apr 19, 2005
    Message Count:
    76
    what is "powdercast" mean
  7. mr_woodster New Member
    Jul 28, 2003
    Message Count:
    1,316
    It means they are 99% of the time first thing to bend/break in bottom end.:nice:
  8. t3-svo New Member
    Apr 19, 2005
    Message Count:
    76
    what are they made of, why do they break easily?
  9. Dan P. Founding Member
    Apr 27, 2002
    Message Count:
    477
    26
    When you cast a metal you have to heat it till it melts and then pour it into a cast and it becomes brittle after doing so because you changed the grain structure of the metal. Where as in forging you start with a blank and you stamp it with a press until the shape is formed. This imparts strength to the piece.
  10. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    They don't break "easily" by any means...I've seen more than 430 rear wheel horsepower go through them for sustained periods of time. They are however typically the first thing that does break if you make too much power (450+), simply because it's hard for a crank, or pistons to "break"...so the rods do.
  11. Bogus SVO New Member
    Jan 18, 2003
    Message Count:
    38
    and the rods are forged also, not powder cast
    most of the time when the break it is at a rod bolt
    powder cast/cracked cap rods did not appare till the early '90s
  12. 88stangmangt New Member
    Nov 25, 2003
    Message Count:
    2,347
    so then for a 400hp build like mine a set of sportsman rods with stock slugs should be fine.??
  13. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Yes, or the stock rods with arp bolts...
  14. 88stangmangt New Member
    Nov 25, 2003
    Message Count:
    2,347
    will do....
Share This Page
