what are the best headlights to get for a foureyed stang, with the current lights you cant see like 10 feet in front of you, so when I get some new ones I wont to get something better than OEM, any suggestions? thanks
I have found that one of the best things to do for the four headlight front is to go through the harness in the front and replacing the wire with something a little heavier. They will also brighten up quite a bit if you clean all the ground connections in the lighting harness.
