TrueBlue95GT said:Weight reduction!!!
95GTvert[bv12] said:For example:
Remove rear seat
Remove Dog bone
Remove trunklining
if vert remove 25lbs fender weight
if gt remove wing
remove front sway bar
Remove front strut tower brace
this stuff should get you better traction and about 100-150lbs (.15sec) of weight reduction plus incress your traction alot (front sway bar)
95GTvert[bv12] said:this stuff should get you better traction and about 100-150lbs (.15sec) of weight reduction plus incress your traction alot (front sway bar)
95snoozer said:I have found this rule of thumb to be WAAAY off.
i get about 1 mph per 50-60 pounds and a mph is more than a 10th
TrueBlue95GT said:Well it all depends on how light your car already is. It's not a linear thing. F=m*a so a=F/m. In other words, to get more acceleration, you either increase force(hp) or decrease mass. For example, say you had a 3800lb vert and you were pushing 300hp and 2500lb coupe making 197hp. They have relatively the same acceleration of .079 (not counting other factors). If you take 100 lbs off of both, you get an acceleration of .081 for the vert and an acceleration of .082 for the coupe. This doesnt sound much, but in physics it is. Sorry for the science lesson.
TrueBlue95GT said:When I took mine off and weighed it, the scale said 9.2lbs. Not much, but everything counts. It's weight reduction as a whole that you'll notice a difference.
