This is your unique opportunity to own a true one-of-a-kind, turn-key, last year of production Electric Red & Titanium Fox Body 1993 Mustang GT 5.0L, Kenne Bell 1500 7psi Supercharged 5-speed Convertible. This is a 2 Owner car with 64,xxx original miles. All modifications have been done by the current Owner.
The car is one of 420 built by Ford in this color combination convertible for 1993. The car is 100% street legal, runs on pump premium fuel and looks & drives excellent! The paint, top and leather interior are all original and in very good condition. Engine runs strong and the 5-speed shifts very smoothly through all the gears. This car handles and corners better than any other Fox Body I’ve ridden in.
The vehicle has won many local shows in the New England area over the past 9 years. You will get compliments wherever you go, whether it’s just driving around or going to a local cruise night or show. I have taken exceptional care of this car within the past nine years. Synthetic fluids have been used all around. The vehicle has always been garaged and hasn’t been wet within the past 6 years. I’ve only used the finest Menzerna polishes and polymer sealant on the paint.
Everything works in this car as it should and the A/C has been converted to R134a, blows cold and the power steering is functional.
Upgrades and modifications include the following:
The car has a clean CT Title and is currently registered in RI. RI doesn’t Title vehicles 10 years or older, so the original CT Title along with my current registration will serve as Proof of Ownership to the new Owner.
I can be reached by cell phone at (401-222-00ZERO-NINE) if you have any questions.
Asking price is $ 10,777. Reasonable offers accepted.
Click link below for FREE CARFAX.
http://www.carfax.com/cfm/FSBO.cfm?report=0A27D3FF6BFF101206C0A969432C5504
Payment would be cash or a local bank cashiers/certified check in-person.
Vehicle is located in Providence, RI 02904.
- Engine and Transmission have 100% original stock internals
- GT-40 Lower Intake
- Kenne Bell 1500 7 psi Supercharger
- Kenne Bell Boost-A-Pump
- Kenne Bell FMU (Fuel Management Unit)
- Aeromotive Adjustable Fuel Pressure Regulator
- Holley 155lph fuel pump
- Steeda Tri-Ax shifter with a Hurst T-Handle
- Energy Suspension urethane motor, transmission and cross-member mounts
- Ford Racing 3.55 gears
- KYB GR-2 front struts
- KYB Gas-a-Just rear shocks and axle dampers
- Hotchkis boxed rear upper and lower control arms
- 18” Boyd Coddington Smoothie II’s
- Falken Azenis P245/40Z18’s up front and P275/35ZR18’s in the rear
- Kenny Brown “Super Sub” welded-in subframe connectors
- Fluidyne radiator w/160 degree thermostat
- Mark VIII electric fan controlled by a DC Control Fan Kit
- PA Performance 3G/130 amp alternator
- BBK Equal-Length Cerami-Coat Shorty Headers
- Felpro exhaust manifold gaskets with Stage 8 Locks
- BBK Hi-Flow X-Pipe Converters
- Flowmaster American Thunder 2-chamber muffler system
- 7 AutoMeter white Phantom gauges (Left & Right bank O2’s, Electric Fuel Pressure, Mechanical Vacuum/Boost and Oil, Fuel Pump Voltage and Water Temperature under the radio) including a one-off shifter bezel that houses the right bank O2 gauge
