gauge hook up help
Just like so...Tap into the FPR line with a Tee.
Edit....I thought you were running a gage feed line.... :bang: I usually just undo the FPR for a moment as use that feed....
A tee on a vac-port-line off the vac-tree also works.
If using a Mitivac, one can undo both ends of a hose and plug one end and pull vac on the other end and see if it holds pressure.
Good luck.
