Gears + Supercharger
Discussion in 'SN95 4.6 Talk' started by Blown 04 Roush, Apr 14, 2008.
  1. Blown 04 Roush New Member
    Jan 4, 2008
    Message Count:
    Pascagoula, MS
    Well, I don't post much here so I will tell you my story. Right after I purchased my Roush in May of '07 the rear end blew up. I replaced everything in the rear end except for the axles. I went with FRPP 4.10's and loved them. A little later I changed up the exhaust to a Mac O/R H with Super 44 Flowmasters, dumped right after the muffler. It made a slight difference, but I wanted more. Well in November of '07, I decided to get blown. I went with the Vortech V2 SQ S-Trim kit. The car pulls like a beast, but I am regretting the 4.10's, simply because I'm shifting so fast, stuggle for traction, and also that 93 octane is over $3.50. Other than better gas mileage, would I benefit at all by switching back to the stock 3.27 gearing, or possibly the slightly different 3.55?
  2. BurningRubber Active Member
    Dec 6, 2004
    Message Count:
    2,738
    48
    Benefits would be slightly better gas mileage (ALOT of MPG depends on your drivning habits, just as much as the car).
    Traction will be a little easier to find.
    You wont run out of gear, or come close to running out of gear at the track.
    The only cons I can think of are cost to perform a gear swap and the fact that you wont get into boost as quick since you have a centrifugal blower.
  3. deftsound Please ask me how much my supercharger cost
    Apr 6, 2004
    Message Count:
    1,683
    36
    Texas City TX
    im blown and have 3.73's, they are ideal, right when i start spinning in first im shifting to second and then i have plenty of time to regain control for third
    most anyone on here that have blowers will tell you that 3.73' are the way to go. Especially if you go to the track, with 4.10's you will have to shift into overdrive...
  4. MyBloodRunsBlue New Member
    Feb 1, 2007
    Message Count:
    127
    wrong! you don't have to switch into 5th gear at the track with 4.10s and a blower....i'm crossing the traps at 6k in 4th gear with my 4.10s....now that is with a 28" tall tire though...go smaller and you will have to pop it into 5th before crossing the traps...
  5. Mossberg Active Member
    Jul 22, 2003
    Message Count:
    1,216
    36
    ATL, Shawty
    This is my fear.
    If I go with a KB, the low end torque will own my tires with the 4.10s.
    I may have to go with 3.55 gears in that case.
  6. LaserSVT Formerly known as *Zap* ImaSammich
    Jun 19, 2007
    Message Count:
    11,530
    320
    133
    Don't matter, had bacon.
    SEXY CHOCOLATE! *stomps foot*
  7. Mossberg Active Member
    Jul 22, 2003
    Message Count:
    1,216
    36
    ATL, Shawty
    Ever get the feeling of Deja Vu? :shrug:
  8. LaserSVT Formerly known as *Zap* ImaSammich
    Jun 19, 2007
    Message Count:
    11,530
    320
    133
    SEXY CHOCOLAT! *stomps foot*
    Its like Deja Vu all over again :shrug:
  9. Mossberg Active Member
    Jul 22, 2003
    Message Count:
    1,216
    36
    ATL, Shawty
  10. Blown 04 Roush New Member
    Jan 4, 2008
    Message Count:
    Pascagoula, MS
    See someone actually told me that if I was to switch to either 3.27's, 3.55's, or at most 3.73's then I would benefit alot because it would allow me to stay in the power band a longer before having to change gears. Can someone elaborate on this or is it bull?
  11. '03GTinFLA New Member
    May 29, 2004
    Message Count:
    492
    St. Petersburg, FL
    I'll let someone else handle the powerband debate but I have a KB 1.7 with 3:73's and I have zero traction in 1st, minimal in 2nd and scratching initiallly in 3rd with 285 BFG KDW's. It's made me learn how to feather the throttle for optimal traction instead of just mashing the pedal and if you have people who are easily impressed you can do big burnouts and drifting type manuevers without much problem. The centri blowers are different though.
  12. TrueBlue03 New Member
    Dec 9, 2003
    Message Count:
    407
    Bay Area, CA
    only $3.50 for 93 octane!? :eek:
    i've been payin $4.05 for 91 :nonono:
    to get back on the thread topic, go with 3.55's or 3.73's.
  13. 01BlkGT Founding Member
    Jan 22, 2002
    Message Count:
    1,016
    ATX
    3.73's are the way to go unless you are planning on running more power in the future so planning ahead is always wise, but at the same time be truthful as well. If you are gonna stay in the normal power range (8-10pis) you'll be fine with 3.73's and won't be running out of gear at the end of the track. If you are gonna be pushing it, then 3.55's will be the way to go unless you plan in running 28" tires at the track and some decent rubber on the street.
  14. deftsound Please ask me how much my supercharger cost
    Apr 6, 2004
    Message Count:
    1,683
    36
    Texas City TX
    yea guess whats going to happen when you decide to upgrade again, you're right im sure you could get away with them at 370hp, anything over 400 though and theres a good chance your going to be shifting into fifth at the local 1/4 track
Share This Page
