I'd like to hookup the radar detector full time so it looks cleaner then having that dangly wire going into my Cig-lighter. Would it be possible to mount the radar detector like normal, and then cut the plug off of the end of its wire (where you normally plug it into the cig lighter), then connect the end of the now exposed wires to the fusebox? Like remove the radio fuse, put the wire in, then put the fuse back in so they both make contact? Would it work?
Can the same be done if I wanted to put a small neon tube under the seats? Thanks
