heater trouble
Discussion in 'Classic Talk' started by big block 460, Jun 1, 2004.
  1. big block 460 New Member
    Mar 13, 2004
    Message Count:
    54
    i tryed to adjust my heater and there is still heat coming through is there anything i can do??
    can i add a shut off value under the hood in one of the heater hoses,, will that do anything to hurt the running hot of the motor??
  2. Max Power New Member
    Jul 31, 2003
    Message Count:
    1,776
    You can install that, but you need controls in the car to run it. If you don't have them from the factory, they are not easy to do.
    You could always just bypass the heater core for the summer, or find out through your heater box assembly what is leaking air. A properly functioning system should let hot air into the cabin.
  3. 67GTA-FB429 New Member
    Dec 16, 2003
    Message Count:
    779
    you can add a valve. that is how the british sporrts cars control the heater. If no hot water is flowing to the core, not hot air will blow through.
  4. big block 460 New Member
    Mar 13, 2004
    Message Count:
    54
    ok thanks guys for the info
    i think i will install a shut off for now till i find out the trouble
  5. Max Power New Member
    Jul 31, 2003
    Message Count:
    1,776
    Problem is, most factory valves are vacuum controlled, and your car probably doesn't have the vacuum switches internally. You may be able to find a cable one and do it manually, but that woiuld be a pita. Just bypass the heater core.
  6. big block 460 New Member
    Mar 13, 2004
    Message Count:
    54
    ok just cut the hoses and conect them together??? under the hood?
  7. Max Power New Member
    Jul 31, 2003
    Message Count:
    1,776
    Yup, you can get a flush tee at any auto parts store for less than $5. Just reconnect the hoses in the fall when you need heat again.
  8. big block 460 New Member
    Mar 13, 2004
    Message Count:
    54
    thanks guys for the help it will be a lot cooler now
Share This Page
