Help with ABS
:DSo the previous owners cut my rear ABS sensors at the floor boards causing my abs light to be on, for what reason i will never know. I found a new set cheap but it says they are for a 00 GT, my question is will they fit and work on a 1995 GT, what is the difference?:D
I'm not sure if they are the same. Usually one cuts the ABS sensors when they install battle boxes, because they cover up the hole that the ABS wire goes through. Is there any wire hanging out of the torque box, or is it gone completely?
Kurt
Ok, well it's not because they installed battle boxes then. By floorboards, you mean it sticks down an inch on the bottom side of the car I assume. The torque box is the area that the lower control arm bolts too. The ABS sensor comes out through a hole in the bottom right near where the lower control arm bolts in. Battle Boxes are a product made by Wild Rides that re enforces that torque box area in order to keep them from getting distorted when you run the car on slicks.
Kurt
