Help!!
Discussion in 'SVT Forum' started by Devilman568, Jan 9, 2008.
  1. Devilman568 New Member
    Jan 9, 2008
    Message Count:
    I just bought my 2001 Cobra convertible . It's got right at 50,000 miles on it and
    4th gear is grinding. The tranny guys are telling me that it needs a new 4th gear and synchro. My freinds say all I need is a aftermarket shift kit (Hurst) with hardened hardware to take care of it . my mechanic says it needs both . Has anyone here had any experience with this . I dont want to drop 9 bills on the tranny if I dont need to . And if allI need is a Kit does anyone know the right kit ?
  2. COBRA90GT Moderator
    Sep 22, 2001
    Message Count:
    6,832
    86
    Adding an aftermarket shifter will not "cure" mechanical transmission problems.
    Avoid shortcuts and have the trans repaired properly. If it means taking it to a 2nd or 3rd trans shop for other opinions/quotes, do so. After the synchro problem has been taken care, feel free to then add your choice of shifter...because let's face it, the factory shifter feels like crap after you've rowed through the gears with an aftermarket shifter.
  3. wraith_2006 New Member
    Dec 9, 2007
    Message Count:
    Does the syncro go out on these trans alot?
  4. Devilman568 New Member
    Jan 9, 2008
    Message Count:
    Help!! revisited
    Is there anyway that my shifter is actually causing 4th to grind? I.E Worn parts creating slack or improper tension.
  5. Devilman568 New Member
    Jan 9, 2008
    Message Count:
    Just to follow up on this , I took the transmission to a shop and it ended up needing a new 4th gear, synchros & input shaft. I installed a Roush ****er . It cost me a pretty penny but it was all worth it .The tranny guy said that the Tremec transmissions are indeed susceptible to this kind of thing. The main cause is speed shifting .
Share This Page
