HID systems..hard to install?
Discussion in 'Mustang Sound & Shine All' started by LXSTASY, Dec 28, 2003.
  1. LXSTASY Founding Member
    Apr 25, 2000
    Message Count:
    932
    Long Island, NY
    i want to get HID's for my lx. I was curious to the difficulty in installing them. Does it just plug into the existing harness or do you have to cut wires? I've seen some advertised as "plug n' play" and others as just the kit. Also the fox body headlight # is 9004.
    Any infor would be appreciated.
    Thanks
    Dan
  2. LXSTASY Founding Member
    Apr 25, 2000
    Message Count:
    932
    Long Island, NY
  3. PoonRacing New Member
    Apr 1, 2003
    Message Count:
    70
    Canton, Ohio
    It not that bad, I just got a kit for my 95 (9007 bulb/8000k), I say the hardest part is try to found a place for the Ballast and the Ignitor (one of each for each side). also you better off wire up the light with their own power source, and use the stock headlight wire to control a relay set, because the HID kit did draw some power, the stock wiring it maybe too weak for that.
    Good Luck. Sam
Share This Page
