A thread like this ran a few days ago, and since then I found some interesting data in a recent comparison test in Car & Driver. Thought you might find the results interesting in terms of different ways to go quickly with your 5.0's (tech content).
Car 1 - Ferrari 612 5.8L (351) naturally aspirated V12 533HP@7250 434 lb-ft@5250 Weight - 4123 lbs. rear gear - 4.18:1 rear tires - 285/40-19
Car 2 - Mercedes Benz CL600 5.5L (336) twin turbo V12 493HP@5000 590 lb-ft@1800 (not a typo) Weight - 4542 lbs. rear gear - 2.65:1 rear tires 265/40-18
0-60 mph - both cars in 4.3 seconds
0-100 mph - Ferrari - 9.4, Benz - 9.8
1/4 mile - Ferrari - 12.5 @119; Benz - 12.6@115
You couldn't ask for much closer performance. The Benz is a few hundred pounds heavier, is short 40HP, but has 160 more lb-ft of torque to work with. Yet performance is almost identical. Note the gear ratios (tire dia. is close) - with all that torque at lower rpm, the Benz has a much longer gear ratio - to make use of the low rpm torque. It also has a 5 spd auto vs. the Ferrari's 6 spd auto - with the narrower power band, the Ferrari is geared (rear end and tranny) to keep the engine in the fat part of its power band (5000-7000) where it can do the most work. And for you low rpm torque fans - the Ferrari has a 16% better power to weight ratio, but the Benz is just as quick. Top speed is a different issue - the Ferrari wins; but it's more aerodynamic so easy comparisons are not possible.
I think this paints a picture of two different ways to get the same result - one through boost/low rpm grunt; one through revs/high rpm power. It's all about understanding how to gear things so you take maximum advantage of the engine's characteristics. By the way, the tester's voted hands down for the Benz in day to day driving. The torque means any time, any gear - mash the gas and you go. Right now.
