How do you remove the headrest
Discussion in '94-95 Tech' started by Mr_302, Oct 24, 2009.
  1. Mr_302 New Member
    Sep 30, 2009
    Message Count:
    18
    TITLE SAYS IT ALL
  2. Chythar Active Member
    Aug 26, 2004
    Message Count:
    1,851
    48
    It's a big PITA as you have found out. If you look at the bar the headrest is on, you'll see one side has a groove in the middle. That's on the side you sit on, not the back of the seat. You need to slide a thin & flexible piece of metal down on that side. When the metal won't go down any farther, push the head rest down a bit and the bar will slip down and past the head rest lock. Then you can remove the head rest.
    I used an old, dull hacksaw blade to remove my head rests. It's thin enough to slide down there and yet strong enough not to break.
    Good luck.
Share This Page
