how to fix seat lean?
Discussion in 'Fox 5.0 Talk' started by fivespeedsteed, Nov 7, 2006.
  1. fivespeedsteed Active Member
    Oct 18, 2003
    Message Count:
    1,023
    38
    Richmond, VA
    i like the stock gt seats, but mine has started to lean like they do, can i take the upholstrey off and bend the frame back and reenforce it, and just put the upholstry back on? is it that easy?
  2. SteedaGT9150 Well-Known Member
    Nov 10, 2004
    Message Count:
    1,993
    27
    58
    Maryland
    i cut a little hole in my carpet and had it welded back
  3. jrichker StangNet's favorite TOOL
    Mar 10, 2000
    Message Count:
    18,896
    31
    98
    Dublin GA
    The seat problems come in two categories:
    1.) The floor pan that holds the front seat mounts cracks and allows the stud that secures the seat to pull out. I recommend that you take two L shaped pieces of 16 gauge steel and overlap the damage. Cut and fit one "L", drill the bolt hole and the weld a bolt in the hole that is for the missing stud. Then weld it in place. The repeat the cut and fit of the next "L" and weld it in place.
    2.) The seat back frame cracks and splits. I riveted mine with some solid monel rivets. You can weld the frame if you don't a have a rivet gun and steel rivets. Removing the head rest is the difficult part. See http://forums.stangnet.com/showthread.php?t=478804&highlight=seat and you'll find pictures and instructions. Once the head rest is off, unzip the upholstery and slide it off the metal frame.
  4. RsStanG1987 I shaved all my pubes playing this game.
    Mar 13, 2004
    Message Count:
    1,292
    24
    48
    Dupont PA
    Category 3 Time to hit the tread mill.
  5. Aliate X New Member
    May 9, 2005
    Message Count:
    649
    9
    Rockland NY
  6. bubba-dough Active Member
    Dec 29, 2004
    Message Count:
    1,056
    38
    Indiana
    lol....yeah its either the floor where the front of the seat mounts is broke (which can be welded quickly and easily) or its the seat itself. It is just pop welds that hold that junk thing together. You can remove the upholstery and twist it back and hold it in place while someone welds it together. you will more than likely see both tears and broken pop welds in the metal.
Share This Page
