How to replace my clutch!
Discussion in 'Fox 5.0 Mustang Tech' started by fiffer, Jun 3, 2005.
  1. fiffer New Member
    Feb 20, 2004
    Message Count:
    First can you tell me if it is my clutch or not. When i get on the throttle in any gear it revs up and barely accelerates. Like the clutch would be slittping all the time. So i ordered a Ram Heavy Duty clutch and im probably putting it in this weekend. Any tips to putting it in or if that is the actual problem would be greatly appreciated. Thanks
  2. cjman15 Banned
    Apr 16, 2004
    Message Count:
    1,016
    Fairfield, PA
    if it's IN GEAR and bogging down, it's not your clutch...
    Sponsored Ad
  3. stang22 Active Member
    Jan 29, 2003
    Message Count:
    1,316
    36
    Destin, Fl.
    Drive down the road about 20-30 miles an hour, put it in 5th and accelerate. If the clutch is bad, it will rev up and not accelerate very fast. If it is the stock clutch, you can try and munually adjust it. Put it in 1st and push the clutch in, the pull the clutch pedal with your hand and you should hear something click. Stock clutches are supposed to auto-adjust, but that doesn't always work.
    Here are some good write-ups for a clutch install.
    http://www.mustang50magazine.com/howto/17821/
    http://www.mustangworks.com/articles/drivetrain/GetaGrip.html
    And for 94-95's.
    http://www.ashentep.com/webpages/clutch_install_for_94.htm
    Tim
  4. HISSIN50 "How long do you think it'll take me to get any he
    Jul 2, 2003
    Message Count:
    30,855
    78
    If your RPMs are rising w/o accelerating, that sounds like clutch slippage. make sure you dont have preload on the cable adjustment before replacing stuff.
    David (5 Spd GT) has a very comprehensive write up for doing a clutch. Search his posts for the write up. :nice:
  5. 5spd GT "the 5.0 owns all"
    Aug 7, 2002
    Message Count:
    9,557
    76
    Arkansas
    Yep it sounds like a slipping clutch problem. As JT mentioned...make sure you have the right preload on your cable... :nice:
    The 25-30mph test in 5th gear may not work (didn't on mine and others) in telling you if the clutch is slipping. It really can depend on your gears and the level of clutch slippage. Mine didn't work either way...in a gear like 5th gear the torque multiplication isn't that great and may not show a slippage of any kind.
    Here is some part numbers of common pieces needed for a clutch install on the 86-95 5.0L’s:
    ARP Flywheel Bolts - ARP-100-2801
    ARP Starter Bolt Kit - ARP-450-3501
    ARP Thread Sealer - ARP-100-9904
    Ford Pressure Plate Bolts and Flywheel Dowel Pin Set - 397-M-6397-A302
    Stock Replacement Flywheel - 397-M-6375-B302
    Heavy Duty Ford Racing Clutch Kit- #M7560A302
    King Cobra Ford Racing Clutch Kit - #M7560C302
    Ford Racing 79-95 Aluminum Driveshaft - FMS-M4602G
    Napa (Fel-pro) Rear Main Seal – Teflon (BS40644), Rubber based (BS40620)
    Fel Pro MicroSleeve for Rear Main Seal – # 16250
    www.buyfordracing.com sells an OEM cable and clutch fork for $40 – 7553-A302
    www.50resto.com or your local parts store carries your throwout bearing, pilot bearing, and rear main seal.
    www.steeda.com has a chart of what correct speedo gear you will need for your application.
    Transmission fluid – Dexron/Mercron III ATF fluid for the T5
    Disclaimer – Do at your own risk and research.
    First jack up the car safely and securely on all four corners and the more room underneath the better so you can remove and install items much easier. Proper jack and jack stand placement is key for safety. A friend or two is probably the best way to go about the install. You will find yourself needing more hands than you have pretty quickly.
    Go ahead and disconnect the negative side of the battery. Go ahead and remove the shifter (or atleast the handle) so you can drop the transmission without the shifter holding it in due to rubbing. Four bolts hold it to the transmission and two bolts hold the shift lever on the shifter base. Pull up on the shifter using the handle if you choose to remove it completely. It will give you better leverage but be careful when it finally pops loose because you might go flying back or scratch interior pieces with the shifter. I put towels around the console to prevent this. Next I would go under the car and start unbolting your mid-pipe, which is held on by a total of 8 bolts (2 for each point of connection). They can be a pain to remove if they haven’t been removed in a while they can seize to the studs/bolts. Use some wd40 or Liquid Wrench to help with this process. A combination of extensions and a swivel would be a good start to getting to the manifold/h-pipe connections. Make sure before you completely drop the pipe that the 02 sensors are disconnected. You can use a flathead screwdriver to pop off the harness connection. Pull the mid-pipe from underneath the car. Now would be a good time to clean it off from all the road grime. Next I go to remove the driveshaft which is held in by 4 bolts in where you will need a 12 point 12 mm socket or wrench to fit over the bolts perfectly. The driveshaft bolts are commonly very stubborn to get off. If you can get a break-over bar on the bolts then you should be able to break them loose. I use the appropriate wrench and put a hollow bar over it and break them loose that way. It helps on the leverage. When you go to remove the bolts you will need to rotate the driveshaft to get an angle on the bolts. When you find the right angle put the car in gear (take your shifter and temporarily pop on the tranny and stick it in gear) and put on the e-brake to prevent the back tires from turning so you can break the bolts loose. Once you have removed all 4 bolts you are now ready to remove the driveshaft. When you pull the driveshaft out from it’s trans housing do not be surprised if transmission fluid comes out (normal). You can buy the driveshaft “plugs” that will be placed where the driveshaft was inputted or you can use a rubber band and ziploc baggy and rig it up to catch any of the fluid so you don’t loose to much.
    Now that the driveshaft is removed you can go ahead and undo any tranny connections that are on the transmission. You need to remove the neutral safety switch (pulls off) and speedo gear (held on by one bolt). Pull them out of the way so they don’t snag on anything. Remove any other connections that you may notice like the clutch cable which is held onto the clutch fork and also held on by a clip (do not loose it). I then start to undo the transmission bellhousing bolts (I remove the tranny with the bellhousing attached). Most of them are 5/8’s bolts with a couple smaller ones near the bottom. Make sure you loosen all the bolts because some go up near the lower intake of the engine and can be accessed thru the engine bay or if you have smaller hands (that I’m not blessed with) you can reach them from the bottom. Your transmission crossmember and bellhousing alignment dowel pins are holding the transmission right now. I next remove the starter, which is held on by 2 bolts, and I don’t undo the connections and just ziptie underneath the car and out of the way. I would go ahead and start bringing a good jack underneath the car accompanied with your buddy to get ready to remove the transmission. Two bottom bolts hold it on and two studs go through the side mounted to the body of the car. Remove all 4 of these with the jack properly supporting the transmission while your doing this. Make sure the jack sits flush and has a good balancer on it to accompany the bulkiness of the transmission. With all the bolts and connections undone you can go ahead and start pulling on the tranny towards the rear of the car as to release the input shaft from the pilot bearing and clutch assembly while also letting the bellhousing coming off the dowel pins. Make sure the engine is supported because it doesn’t have the transmission’s weight to counter the tilt. Another jack would be nice. Put a board to even out the weight distribution over the oil pan. Once the input shaft is clear of the clutch assembly (as not to get damaged) and you have wiggled it loose go ahead and drop the transmission slowly while not tilting it so you don’t loose transmission fluid through the speedo gear hole. Remove the transmission out of the way of the bottom of the car. It would be a good time to clean the transmission, crossmember, and driveshaft at this point. Use some degreaser and some “elbow grease” at your local car wash to help you out. You can clean up the bottom end of the car the same way. Good time to do it right? Check your input shaft bearing retainer and shaft itself for scouring or any other kind of damage. It is a good idea to replace all your clutch assembly parts together. Now you can go ahead and remove your pressure plate/clutch disc. If you want to reuse the pressure plate and disc for some reason. Back the 6 pressure plate bolts off evenly as not to warp the plate or disc. When you loosen it watch out because it is heavier than one would think so be ready to catch it or have your friend hold on to it. Once removed you can check the disc and pressure plate for problems and wear to see what is going on with your car. You can now see the flywheel that is held on by 6 bolts as well. These bolts are on pretty tight and I personally use an impact wrench to remove the bolts. I do them evenly as well to prevent any kind of warping. The flywheel weighs 21 lbs so be ready to catch it as well. Remove the flexplate (goes between bellhousing and block). Once the flywheel is removed and out of the way inspect the teeth on it and condition of the clutch disc mating surface. You may need a new teeth ring gear or you may not. You will want to have your flywheel resurfaced (turned) at your local machine shop. They can charge anywhere from $25-$40 bucks for the resurfacing. It will provide for a nice smooth (unspotted) fresh surface for your new disc and pressure plate to work with. Well worth the money if you consider the negatives of not doing it. Since the flywheel is removed you can now see the rear main seal and pilot bearing. If the rear main seal is not leaking DO NOT touch it because it is doing it’s job. A rear main seal install can be tricky. If you see you need to remove it (leaking) you can use a flathead screwdriver to pinch the seal and remove it. You can use a slide hammer as well. You DO NOT want to scratch the crankshaft at all when removing the seal. If you do you will need to put on a sleeve to prevent it from leaking. So be very careful on the crankshaft end. Some have put a screwdriver on the block side of the seal and pryed it out CAREFULLY to remove it. Once removed (in which ever method you chose) clean up the crankshaft and block area where the seal goes into it and put some oil in there to help the seal to go in smoother. I would go ahead and clean the back of your heads and block while your at it. Simple Green and some nice clean smooth rags will be suffice. To install the new rear main seal you want to take your time with this. Put some oil on the inside ring of the seal where it rides on the crankshaft itself. Install the rear main seal EVENLY. You can use the old rear main seal to tap against it to put the seal in the housing. Tap it in a circle slightly and put it flush with the block. Don’t bottom out the seal. Some like to put silicone on the outside ring of the seal (where it meets the block) – it acts like a bridge to keep the oil away. Don’t put any high-temp silicone on the seal part where it meets the crankshaft because it needs to turn, not like it would stop it from turning.
    I would go ahead and inspect the pilot bearing by rubbing your “clean” finger in the hole to see if you feel any scouring or rough edges that could effect the ability for your input shaft to function properly and smoothly. If it seems smooth and visually looks good I would go ahead and keep it in there. If your one of those people that are a “miswell while I’m down here” type person then go ahead and change it out. Put some grease in the pilot bearing hole and get a brass punch the same diameter of the hole. You then stick the punch in the hole and hammer the punch into the grease to remove the bearing hydraulically. The bearing will push out as you use the grease as a displacement. You may need to add grease a couple times as more surface area is revealed and it will eventually come out. You may also use a slide hammer on the pilot bearing as well. Most pilot bearings are pre-greased from the factory but I put some bearing grease (just a bit more) on the inside/outside to help with lubrication. Take the bearing (after taking notice of how the pilot bearing was in previously and install it the same direction). Tap it in a circular motion evenly so it doesn’t become offset. Make it flush with the block as well I believe. You are now ready to reinstall the flywheel. Take the new or used (but resurfaced) flywheel and rotate it so the bolt holes (they are offset) match with the flywheel holes and put in a couple bolts to hold the flywheel up there. Before doing this though I would clean up the crankshaft threads a bit of any oil. Just as well MAKE SURE you clean all the clutch assembly parts well before installing them with some carb or brake cleaner to take off human grease and rust inhibitors. Anyways, once the flywheel is held up there go ahead and get some loc-tite and apply them on the threads of the flywheel bolts. That is all I have needed and I have go no oil leak. Some use thread sealer for extra security from leaks. Use it at your own reasoning. Put all the bolts in with some loc-tite and go ahead and start tightening them in a “star” pattern (evenly). The flywheel bolts need to be torqued to 90ft. lbs using a torque wrench. Make sure you clean off the flywheel of any oil or grease from your hands so it doesn’t effect clutch performance and grab. Next you can go ahead and get your clutch disc ready and I’m hoping you got a clutch alignment tool (10 spline – 1/16th input shaft size) and make sure the clutch disc is facing the correct way. Most will be labeled either ENGINE SIDE or FLYWHEEL SIDE. Put the alignment tool in the clutch disc and stab it into the pilot bearing. It may support itself. Get your buddy to hold the input shaft as evenly as he can while you take the pressure plate and set it on the flywheel alignment dowel pins (you need those alignment dowel pins to align and balance the pressure plate properly). The pressure plate will sit on the pins and hold itself. Now get your 6 pressure plate bolts and start threading them in. Go ahead and tighten the pressure plate bolts in a star pattern (evenly and go thru it a few times so you don’t warp the plate). While it is being tightened have your friend have the clutch alignment tool centered for best performance. Torque the pressure plate bolts to 24 ft. lbs (most clutch manufacturer’s recommend that). It probably wouldn’t hurt to put a bit of loc-tite on those bolts but it isn’t completely necessary. You know have the clutch assembly put together. Remove the clutch alignment tool.
    Go back to your transmission and check your throwout bearing (TOB) for wear but I would suggest replacing it anyways because it is fairly cheap. Pay attention to how the old one is installed on your retainer shaft. Remove it off the clips and install the new one and check to see if it rides smoothly and turns. You can do this by moving the clutch fork (natural movement) up and down the shaft. Put some high-temp grease on the throwout bearing where it mates against the pressure plate forks. A tip: The “fat-end” of the throwout bearing goes against the pressure plate teeth. You are now ready to install the transmission. Put it on the jack for support and get your buddy to help you jack it up there. Keep in mind that the input shaft on your transmission has to slide in smoothly into the input shaft (the job of the clutch alignment tool). You may need to spin the input shaft so it will “spline” into the disc. As you are getting the spline to line up you need to make sure the bellhousing alignment dowel pins are still in place and that the bellhousing slides over them which will help align everything properly. Go ahead and install the bellhousing and transmission bolts and tighten them up. Now to go back to the transmission install. If it doesn’t “pop” in you need to check for any clearance issues or objects in the way. You should not have to “pull” the transmission on with any bolts…so be mindful of that. Tighten all the bolts down tight so they won’t come loose. Start reconnecting the clutch cable with the clip and onto the clutch fork. Reinstall the speedo gear (a good time to replace it by the way if it is all chewed up) and the neutral safety switch. It would be a good idea to go ahead and put on the crossmember to hold up the transmission and then remove the jack from underneath the car. You may now get ready to install your driveshaft. Pull your fluid plug or ziploc bag away and slide the driveshaft splines into the transmission and start threading in the driveshaft bolts. Put loc-tite on them because you definitely don’t want them bolts to come loose. Torque them down to 100 ft. lbs. Go ahead and put on the mid-pipe and check for any kind of wires or connections that might melt on the exhaust pipes. Fix it (zipties work wonders). Plug in your 02 sensors. Do a quick visual check underneath the car for anything loose or not needed. Go inside your car and reinstall your shifter. Clean the shifter mounting area with a gasket scraper of the old silicone or gasket being careful not to get any in your tranny. Lay down a bead of high-temp silicone around the mounting area and bolt the shifter down (4 bolts) and reinstall the shifter lever/cover/and knob after your sure you got the stop bolts and shifter shifting properly. Just as well make sure the cover is installed around the shifter to keep dirt out of your interior and road noise down. Finally reconnect the battery and clean-up.
    The install is now done but when aftermarket pieces are applied you will need to adjust where the clutch engages and disengages to your liking. There are aftermarket pieces like clutch cable firewall adjusters, adjustable clutch cables (you adjust at the clutch fork), and aftermarket quadrants from maximum motorsports, UPR, Steeda, etc. If you use a firewall clutch cable adjuster you can turn it counterclockwise and make the clutch pedal grab closer to the floor. If you turn it counterclockwise it will raise the pedal grab higher up. Replacing the stock plastic quadrant is a good idea and can soften up your pedal as well with the feel. I have seen and learned from personal experience that an OEM non-adjustable cable with a firewall adjuster is a great combo to have and keeps the pedal feel softer than what it could be.
    Follow proper break-in procedure by being easy on the car for the first 400-500 miles to properly seat everything.
    Here is a really good article with pics I thought I would add after I found it - http://www.badassmustangs.com/tech/idx/9/002/article/
    Good Luck:nice:
  6. stang22 Active Member
    Jan 29, 2003
    Message Count:
    1,316
    36
    Destin, Fl.
    Do you have any pics? That is an awesome write-up. Throw some pics in there for reference and it becomes platinum. :nice:
    Tim
  7. 5spd GT "the 5.0 owns all"
    Aug 7, 2002
    Message Count:
    9,557
    76
    Arkansas
    Thanks Tim...nope I don't have any pics with it...I'm not real familiar on having the host and all but I can post attachments... :p I have to have some though first...I don't have any clutch install pics...but I do got h/c/i install/removal pics...I wonder if those will help :D
    I think I might throw in those articles you posted in the 2nd post into my write-up at the bottom like the other. It would become real helpful then... :)
  8. v8only Active Member
    Jul 4, 2003
    Message Count:
    2,223
    46
    I've got my engine and trans laying on the pavement right now with the bell and clutch still mounted. It's all coming off this monday (putting in new engine) I could take pics of the bell, fork and clutch etc if anyone needs them.
  9. DoubleAgentMan Founding Member
    May 3, 2002
    Message Count:
    151
    South Texas
    5spd GT
    Awesome write up man!Nice link also!
    I myslef am coming up on this job for the 1st time and was really considering getting a shop to do it...Now after reading that and looking at that link,I can hear that little voice in my head sayin' ..."You can do it!"....
    Doesn't everyone get those voices?N/M,don't answer that...;)
    Won't be easy but,after reading,its definately worth a shot...especially considering what local shops would charge in labor AND you wouldn't know for SURE if they did it "RIGHT"...
    Great post man...
  10. cobradvm New Member
    Sep 2, 2003
    Message Count:
    246
    Woodinville, WA
    Clutch swaps are really bolt off/bolt on jobs - its more a pain doing it all lying on your back (unless you have a lift).
    Biggest problems I had first time doing it were frozen bolts on the H pipe - bust one off and had to drill it out of the header flange. The other was dumping tranny fluid everywhere - now I drain it first before dropping the tranny. I make sure the bottom of the tranny is spotless, and drain it into a clean container, and then reuse it. If you haven't changed your tranny fluid in a while I would drain it and refill with new fluid. There are lots of good posts on here and Corral on clutch swaps - take your time and you'll be fine.
    One other thing when putting the tranny back in - I tried the balancing it on a jack idea - royal PITA - just lie on your back (not on the creeper) on the floor crossways ie perpendicular to the way the driveshaft runs, slide the tranny over to you and then drag it onto your chest. Then a simple bench press and pop it right in. If you are on the creeper, you will move around too much as you slide it in. There are other little tips and tricks but post or search when you get stuck somewhere, and we'll get the answer for you.
    Good luck
  11. BaXTeR3221 Member
    Jan 12, 2004
    Message Count:
    982
    Orange County, NY
    I had a similar issue last summer. Turned out my clutch was fine, but the rear main seal was leaking lots of oil onto the clutch and making it slip. Replaced everything and now it runs beautifully.
  12. 5spd GT "the 5.0 owns all"
    Aug 7, 2002
    Message Count:
    9,557
    76
    Arkansas
    I still don't see how oil from the rear main seal (unless it comes thru the flywheel bolts) gets on the clutch unless it was a pretty serious leak. I guess if you got enough it could get slung on the side of the bellhousing from the flywheel and snake it's way into the clutch disc/flywheel mating area:shrug:
    Thanks for the props DoubleAgentMan:nice:
  13. _jb_ New Member
    Mar 5, 2004
    Message Count:
    819
    Michigan, Berrien County
    Maybe from the wind generated from the flywheel/clutch moving around throws the oil around. :shrug:
Share This Page
