how to use calcon?
Discussion in '94-95 5.0 Tuning' started by Mustangless, Apr 1, 2006.
  1. Mustangless New Member
    Jun 28, 2003
    Message Count:
    911
    home
    How do I use calcon with my tweecer r/t? I have all the stuff conected and it does not move unless I push the start logging button. Then it just shows all the stuff in the bottom left corner at 0. How do I do this?
    I have caledit v1.30a9 calcon v1.0a7
    6) Click the tab at the top labeled "Input / Output".
    I do not see that under caledit ^
    Do I need version v1.20b not a?
  2. Zero Signal Active Member
    Feb 24, 2003
    Message Count:
    2,646
    46
    Tucson, AZ
    Did you setup the payload on your .ccf file before you uploaded it? When you setup your tune, you gotta go the utilities tab in CalEdit, click the functions you want to log and hit 'Payload' to load the selection onto the file (the checkmarks will all dissapear, but it's okay). Then save the file and load it to the tweecer and try again.
  3. Methodical Active Member
    Dec 1, 2003
    Message Count:
    1,187
    36
    Clinton, MD
    Yeah what he says. Also, don't forget to save your payload.
  4. Mustangless New Member
    Jun 28, 2003
    Message Count:
    911
    home
    when I put it on either 1-4 the fuel pump runs for awhile. Then i click write to tweecer and it runs and runs. I try starting the car and it dies with the fuel pump running.
    I have read my eec and loaded the u4p0.bin which is what my comptuer is.
    I get no display under calcon.
    I check log file, but do I mess wtith the boxes under it?
    When i go to calcon, the tweecer rt light is lit up.
  5. Methodical Active Member
    Dec 1, 2003
    Message Count:
    1,187
    36
    Clinton, MD
    Go the the EECtuning forum it has a section there where folks ask those same questions when they had installation isses. Do a search over there and I bet you will find the answer. It sort of sounds like you may have something mixed up with the computer file you are using. I know I had similar problem and what I found was that I accidentally changed the j4j1 at the bottom to A9l - it screwed everything up. With that in mind here's a tip on how to clear KAMs without having to disconnect the battery etc. Install a bad tune to one of the 4 positions - in my case I put A9l in my No. 4 position. When I load a new where there were changes to the MAF or TB airflow rates etc. I install the new tune then turn the dial to the bad tune - Wam, the KAMs are clear or computer is reset. Some peeps have used this method as the theft device. They would load it in the No. 1 position and remove the dial from the car. I would not suggest this method because if you lose the dial or it gets damaged, the TwEECer defaults to the No. 1 tune, which would be the bad tune and the car will not run.
    Again check in the EECtuning forum under hardware install section. Have you check there yet?
    Peace
Share This Page
