i need some help
Discussion in '2005 - 2012 Specific V6 Tech' started by inkednculinary, Mar 29, 2009.
  1. inkednculinary New Member
    Mar 29, 2009
    Message Count:
    Charlotte, NC
    i have an 07 mustang and I was recently changing the rear brakes on it. when i took the calibers off in order to put them back on with the new brake pads i had to use the c-clamp to pust the caliber back to fit over the new pads. now my back brakes arent working at all. theres no air in the lines everything is fine. but i found out that apparently you have to use some certain tool to push the caliber back on some newer model cars. what should i do. did i royally screw my calibers up by using the c-clamp to push them back withouth the tool or can this be fixed easy without alot of work. need some input thanks.
  2. BlownFiveLiter have car, will race....wait, it doesn't run
    Oct 23, 2004
    Message Count:
    5,458
    20
    88
    Chicagoland
    You'll need new calipers, sorry. Brakes are one area where you definitely don't want to start rigging things to work, such as attempting a repair of a damaged caliper. You're not the first person to find this out the hard way, unfortunately. :welcome: to :SNSign: though!
  3. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    7200 feet
Share This Page
