'66 289, mallory unilite electronic distributor (brand new module), new ignition switch, plugs, wires.
a couple days ago i go to start my car. it starts kinda hard, idles for about 5 seconds, then dies. would not start after that point, so i check for fuel. carb's fine. check for spark, none. check the coil, which is putting out plenty of voltage. so i figure it has to be my dizzy. i got this unilite used, so i don't fully know what condition it's in. i have hear that they fail somewhat easily, so i buy a new module off summit. popped it in today, turned the engine over, and it just barley started to idle, but then it died. no spark once again.
i haven't done any modifications to the wiring, or anything at all, for that matter, since i put in the unilite a few months ago. what could have caused it to fail? and, if it's the case, what caused the brand new module to fail, if it did? how could i check the module if it works or not? could be problem be something other than the dizzy/coil/plugs/wires?
thanks in advance
thanks in advance
