Ignition problems?
Discussion in 'Fox 5.0 Tuning' started by daxjb, Feb 27, 2009.
  1. daxjb New Member
    Jun 20, 2005
    Message Count:
    I have a 93 lx with a 302.My motor is missing at 4000 rpm's .It seems to get better when the motor warms up .I checked my voltage at the coil and it's only 10.5 volts.Just out of curiosity i used an engine ground for the negative and i measured 12.5 volts.Seems as if i have a bad ground.I relocated my battery to the back so i ran an 8 guage to the front for the computer ground.Looking at a schematic shows the negative for the coil comes from the computer.I checked the ground at the computer for continuity and it's good.I even tried another A9L to see if the computer was bad and it did the same thing.I know the 2nd computer is good.If anyone can think of anything i would greatly appreciate it.
  2. Black1987Stang New Member
    Aug 23, 2004
    Message Count:
    1,457
    Yeah the coil ground goes to the computers, it's mixed in with the pip sensor in the distributor which tells the computer to ground the coil and make it spark....so idk if it will serve as a 100% ground....I'm sure Jrichker or Hissin would know....I know I've checked it before but I forget my reading
    If you got a MSD 6AL box take out the rev limiter chip, my friend was doing the exact same at 4k, took out the chip and all was good...
  3. fstrbz New Member
    May 13, 2005
    Message Count:
    where is all your grounds connected? frame, engine, computer ?
  4. jrichker StangNet's favorite TOOL
    Mar 10, 2000
    Message Count:
    18,439
    11
    88
    How good are the coil, distributor cap and wires? If you have a spare coil laying around, try swapping it out.
Share This Page
