instrument cluster swap
Discussion in 'SN95 4.6 Talk' started by pipeguy, Apr 11, 2008.
  1. pipeguy New Member
    Apr 11, 2008
    Message Count:
    18
    hey guys,tried to swap a mph to kmh cluster, and theft light is on and car will not start, if i put thed old one back it starts,what gives. i apreciate the help, thanks.
  2. bdcardinal tree hugger
    Jun 10, 2003
    Message Count:
    3,670
    56
    santa barbara, CA
    what year is the mustang? did you properly program the PATS?
  3. pipeguy New Member
    Apr 11, 2008
    Message Count:
    18
    its a 2000 gt and how do you program pats, and what is pats, thanks
  4. bdcardinal tree hugger
    Jun 10, 2003
    Message Count:
    3,670
    56
    santa barbara, CA
    PATS=Passive Anti Theft System. you need a factory scan tool to program PATS, ie WDS, NGS+, IDS, PDS.
    any partular reason you are changing clusters? the OEM ones list both MPH and KMH
  5. pipeguy New Member
    Apr 11, 2008
    Message Count:
    18
    wife has a hard time seeing the small numbers at night, thats all , i found the cluster for 80 bucks on craigslist, i thought i couldnt go wrong, looks like its a bit more complicated than i thought, but now that i have it i would like to follow through with it.
  6. pipeguy New Member
    Apr 11, 2008
    Message Count:
    18
    i bought the car last summer in the states and brought it back home, thats the reason for the cluster beeing in miles
  7. CMEFLY New Member
    Dec 12, 2003
    Message Count:
    64
    bonney lake WA.
    You can take it to the dealer and have the new cluster programmed to your car. Or you can buy a sct x cal3 and have it programmed with a custom tune for your car to turn pats off. They run 379.00 from lasota racing and you get 3 custom tunes plus you can get some extra horsepower.
  8. Pearl02 Member
    Nov 27, 2004
    Message Count:
    496
    Kansas City
    There are "white" circuit boards on both gauges. Remove the board from your old cluster and put it on your new cluster. This is what I had to do when I switched my GT cluster over to the Bullitt cluster. Car should start right up. It not hard to do. Just take your time. Will save you a dealer reprogramming cost. Pearl02.
  9. Mossberg Active Member
    Jul 22, 2003
    Message Count:
    1,216
    36
    ATL, Shawty
    Yep, this is the answer to your problem. Dealer trip is not needed.
  10. pipeguy New Member
    Apr 11, 2008
    Message Count:
    18
    what is on the whte circuit boards, will i have to reprogram the speedo, or is just the memory of the pats, thanks dudes
  11. pipeguy New Member
    Apr 11, 2008
    Message Count:
    18
    dudes thanks for the hep, swaped circuit boars now car starts, yaaahoooo!!!!
Share This Page
