intake setup
Discussion in '94-95 Talk' started by pacesco, Aug 9, 2007.
  1. pacesco New Member
    Jan 21, 2004
    Message Count:
    24
    ok, here's what I have.
    347cui
    scat forged steel crank
    h-beam rods
    balanced
    RHS cyclone 200/64 heads
    Comp cam duration @ .5 lift, intake 224 exhaust 236
    10:1 compresion ratio (should be able to run pump gas)
    AODE trans
    2800rpm stall converter
    125hp wet zex nitrous kit to install
    here's my question...:shrug:
    what intake set up should i run? i was looking at the BBK SSI set up??? also what size injectors, fuel pump, and should i change the fuel rails and pressure regulator? should i change the computer, what is the best one to go with?
    any help on this would be great...:)
    brian
  2. 95strokerPSU Member
    Jul 29, 2004
    Message Count:
    987
    Sacramento from Philly
    Edelbrock RPM II and 42lbers.
  3. pacesco New Member
    Jan 21, 2004
    Message Count:
    24
    what computer are you running?
  4. pacesco New Member
    Jan 21, 2004
    Message Count:
    24
    i have a gt40 intake that i was thinking about sending out to extrude hone and matched to my intake ports on the heads.. any thoughts?
  5. RIO5.0 Mustang Master
    Feb 17, 2001
    Message Count:
    6,806
    86
    N.H.
    Your not gonna Extrude Hone a GT40 a whole bunch...The tubing is thin stuff as it is...Something tells me the GT40 is not the best choice for your set-up...and the BBK is kinda so so power wise to the normal 5.0 intakes..Both look nice but they're not the best performers..
    I would think the stock ECC and an SC would do just fine...depends on your budget??
  6. bimmertech New Member
    May 4, 2005
    Message Count:
    1,129
    merriam, ks
    :stupid:
    if you decide to man up on the cam/converter then do a vic jr.
Share This Page
