Intermittent Gauges
Discussion in 'Classic Mustangs' started by Botman_68Conv, Aug 8, 2009.
  1. Botman_68Conv New Member
    Aug 10, 2001
    Message Count:
    San Diego
    • 1968 gauge cluster
    • Replaced the Instrument Voltage Regulator (IVR)
    • Gauges go on and off while driving.
    A month ago all my gauges died so I assumed it was the IVR. I ordered and replaced that part and during my test drive everything seemed fine. I drove the car the next day and after about twenty minutes the gauges went dead again, then they started working, then they died, then they worked. You get the idea.
    It sounds like a loose ground so I plan to take the cluster out and physically check the connections but since it is intermittent I do not expect putting a meter on it will be definitive.
    Any other ideas on what it could be?
  2. dewdrop Member
    Oct 9, 2005
    Message Count:
    42
    East Tenn
    check short
    Check for a short / bare wire on feed to all the guages and fuel. If any of those wired hit ground can screw up the IVR and ruin it over time. Been there...................
  3. Botman_68Conv New Member
    Aug 10, 2001
    Message Count:
    San Diego
    Update
    I took the instrument cluster out and with the harness still pligged in I hooked the battery back up. I get a clean 12v coming to the IVR. I checked the output from the IVR and it cycles to 10v about every 10 seconds. From what I ready this is not right.
    I plan to order the electronic voltage regulator from The Paddock. I now I could build my own but just do not trust my skills to get it right.
    While I was there I verified the ground on the back of the cluster is excellent and the connection from the IVR out to the gauges are solid.
    The wires surprisingly looked good and I see no bare wires after 40+ years. One huge benefit for me is my parents are the original owners so I have been working on this car since I was a kid.
  4. tx65coupe Active Member
    Aug 19, 2008
    Message Count:
    1,497
    36
    The electronic IVR is a good upgrade.
    I went through several of the 20-30 dollar ones and none worked right.
    I was going to order an electronic one like you mentioned. It seems NPD and Paddock are the only places that carry it.
    Since my Dad is an electrical engineer and he was bored one Saturday, he took apart one of the new junk ones that didn't get sent back and made an electronic one out of parts from Radio Shack for less than 10 bucks.
    Here is a link to a tech article about doing something similar.
    IVR
    To prevent future issues, I added another ground wire from the back of the cluster to the dash support.
Share This Page
