Just an explosion
Discussion in 'Mustang II' started by IICrazy, Feb 18, 2004.
  1. IICrazy taken away
    Mar 28, 2003
    Message Count:
    1,415
    36
    I was working on the distributor and Stupid me didn't turn the igniton off. I pulled the distributor out and the damn thing exploded sot my oil breather and filler caps out of the valve covers and singed the side of my face and arms, so know I have no eyebrow or hair on the left side.
    I just want to know what happened and if it's that bad. everything appears to be fine. except for me.
    I'll have a pic up soon
  2. IICrazy taken away
    Mar 28, 2003
    Message Count:
    1,415
    36
    Heres some pics
    My poor hair
    [IMG]
    Now what I think I still look good :)
    [IMG]
  3. THE COBRAMAN pig 'rassler
    Mar 11, 1999
    Message Count:
    1,994
    Sounds like the crankcase is (was) full of gasoline/vapor.
  4. dmoody Founding Member
    Nov 4, 2002
    Message Count:
    798
    That's a new one for me. I'm assuming you had a push-in valve cap and not the twist-on ones that stock Ford valve covers come with?
    d
  5. IICrazy taken away
    Mar 28, 2003
    Message Count:
    1,415
    36
    yea I found the thing 10 feet away, I think it bounced off the garage ceiling.
  6. IICrazy taken away
    Mar 28, 2003
    Message Count:
    1,415
    36
    Yea, I just called my dad and he laughed his arse off, and thats the same thing that he said, but do you know if it could of damaged anything on the car.
  7. chaka Founding Member
    Mar 1, 2002
    Message Count:
    1,371
    Probably just the dist. that went flying 10'. I don't see how anything could get damaged.
  8. THE COBRAMAN pig 'rassler
    Mar 11, 1999
    Message Count:
    1,994
    It's possible that the oil pan seals and crank seal may have been pushed out, but the breathers and dist holes might have been enough vent area to avoid it. You'll just have to eyeball them and check for leaks after it's running again.
    May want to look into why there was that much combustible vapor in the crankcase, though. Flooded maybe?
  9. IICrazy taken away
    Mar 28, 2003
    Message Count:
    1,415
    36
    Well I checked everything and got it going no problem now. just freakin scary
  10. 75stang302 Founding Member
    Mar 31, 2002
    Message Count:
    1,036
    my guess would be that your carb was flooding filling the crankcase with fuel
  11. dmoody Founding Member
    Nov 4, 2002
    Message Count:
    798
    75stang302 is probably right... sometimes carbs can fill the engine with fuel, especially if it has been parked on a hill or sloop.
    d
Share This Page
